Misses under load #1465667
07/09/13 10:58 PM
07/09/13 10:58 PM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
My 69 440 Six Pack was running great then all of a sudden, it started missing under load. Idle and revving in neutral is fine. As soon as I put it in Drive, it starts to miss. I checked the wires and did a vacuum test. Everything fine there. Suggestions?
Re: Misses under load [Re: moparcanuk] #1465668
07/10/13 01:35 AM
07/10/13 01:35 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Start with the spark plugs. just replace them.. everyone has a favorite.. I like Autolite...
could also be, a bad wire, or the coil could be arching from the primary wire to secondary wire... (replace coil).
It takes more voltage to fire a cylinder under load.
