Hemi 5.7 to a duster #1465420
07/09/13 03:10 PM
07/09/13 03:10 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
do you know who might make a wiring harness or have a wiring schematic to put a 5.7 Hemi into a Duster. Or have you put a 5.7 Hemi into a 70' mopar
Re: Hemi 5.7 to a duster [Re: robnbird] #1465421
07/09/13 06:20 PM
07/09/13 06:20 PM
dogdays Offline
dogdays  Offline
Maybe we need to have a new page just for late Mag and Hemi swaps?
MODS?
R.
Re: Hemi 5.7 to a duster [Re: robnbird] #1465422
07/09/13 06:27 PM
07/09/13 06:27 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
there is a section for Gen3 hemi conversions over on FABO i think answers to most topics regarding these swaps can be found over there if you do alitle digging.
Re: Hemi 5.7 to a duster [Re: 1Fast340] #1465423
07/09/13 06:29 PM
07/09/13 06:29 PM
dogdays Offline
dogdays  Offline
But we keep getting them here at Moparts!
R.
Re: Hemi 5.7 to a duster [Re: 1Fast340] #1465424
07/09/13 06:39 PM
07/09/13 06:39 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Muchas Gracias senor
Re: Hemi 5.7 to a duster [Re: robnbird] #1465425
07/09/13 06:43 PM
07/09/13 06:43 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Below is a Google link to all the topics on Moparts containing "3rd gen";
-> Mopars Google-function
Enjoy!
Re: Hemi 5.7 to a duster [Re: BigBlockMopar] #1465426
07/09/13 07:11 PM
07/09/13 07:11 PM
Ohio
blown71duster Offline
Ohio
You could contact Dave or Chris at Modern Muscle or Hotwire, they can sell you a wiring harness that is plug and play with stock ecm.
You will have to change the oil pan, TTI mounts, TTI headers with a manual box or you can change to a Borgeson Power steering box, TTI now making headers to fit that box.
Need a special flex plate to bolt up to a small block auto trans or modern manual or auto.
Will need to fab up an efi fuel system , in tank works the best with a corvette style fuel filter.
3g Style radiator with inlet and outlets on passenger side
Assuming you are running a manual gearbox and 727 auto, expect cost to be around $3500+ for items listed .
Re: Hemi 5.7 to a duster [Re: blown71duster] #1465427
07/10/13 01:06 AM
07/10/13 01:06 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
now throw some turbos on it and really pull to the stripe.......
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Hemi 5.7 to a duster [Re: cheapstreetdustr] #1465428
07/10/13 01:34 AM
07/10/13 01:34 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
https://board.moparts.org/ubbthreads/favl...amp;postmarker= here's mine, granted it's is crate motor with all the wiring/comps to go with it, but it shows the other problems, GDemon has done a couple few, contact him. It's not too bad but well worth it.
-Daty
Re: Hemi 5.7 to a duster [Re: Daty Rogers] #1465429
07/10/13 02:09 PM
07/10/13 02:09 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
http://www.3gduster.com/
Look for "uhcoog1" on here.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Hemi 5.7 to a duster [Re: blown71duster] #1465430
07/10/13 11:38 PM
07/10/13 11:38 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
You could contact Dave or Chris at Modern Muscle or Hotwire, they can sell you a wiring harness that is plug and play with stock .
Yep call Modern Muscle. I bought a 5.7 harness/engine managment system for my 55 Dodge truck project from them. Great support and service. The harness is actually built by Hot Wire. You could also give Chris at Hot Wire a call, he will answer all your questions.
Re: Hemi 5.7 to a duster [Re: Dabee] #1465431
08/20/13 11:08 PM
08/20/13 11:08 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
I got mine at Hotwireauto.com. Chris Squiers makes the complete wiring harness to retrofit a Gen III Hemi and a programmed computer.
