Re: W2 cc chamber size
[Re: Sb Valiant]
#1465120
07/09/13 01:36 AM
07/09/13 01:36 AM
Posts: 6,148 Melbourne , Australia
LA360
I doubt they could go that low without welding. From memory you will get down to the mid to low 60's, anymore the decks are too thin and you hit the valve seats. Angle milling would be better, but I can't speak from experience with that. Your heads were the early ones from memory, so they won't be as thick as some of the last model ones, well the 810 casting I had weren't anyway.
Alan Jones
[Re: Sb Valiant]
#1465124
07/09/13 08:04 AM
07/09/13 08:04 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Great idea buying one Brock but being as young as you are buy one a little better one. Heck your Friends will gladly throw you a few bucks over the years to have there stuff checked. I bought this one and I can't tell you how many times I've used it. http://www.summitracing.com/parts/sum-911581/overview/
[Re: Blucuda413]
#1465126
07/09/13 11:12 AM
07/09/13 11:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Another way to go cheap is to just use a piece of plexiglass and for a buret go to your local feed and seed and buy a large animal syringe which is very cheap. The syringe I have I believe holds 65cc so for the big items you will have to fill it again but the plunger is very positive and it works very well.
Yep... and it'll last longer... I had the glass buret shown and it fell over when I bumped it.. broke the valve off... you can buy plastic burets also... my W-2s are right at 70cc... but I had to polish them to get the balance on them and a truing cut .. stock they ranged about 70 to 73 on the castings... I milled one set down .060 which took it down to a closed chamber ... I wouldnt go any farther.. I was starting to worry about the deck thickness but its fine
[Re: Sb Valiant]
#1465127
07/09/13 11:19 AM
07/09/13 11:19 AM
MR_P_BODY
I didn't know they sold those! Would it be cheaper to buy one rather then to have machine shop check it? Could you cc pistons with this also?
Yes... grease the top ring and put the piston down 1/2" and fill it... you can figure the volume on the 1/2" times the bore and come up with X CCs for that area then subtract you fill amount to get your number
