Line Locks
#1465064
07/08/13 10:44 PM
07/08/13 10:44 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Im considering installing a Line Lock on my shorty with the OD833. Not to be used for burnouts but as a hill holder. We have some fairly steep hills with stoplights around here. Do any of you guys have 1 on your truck. What brand. Where did you mount it? Im thinking about a bracket that uses the 2 master cylinder/booster studs for mounting. I hve a 2 spoke steering wheel with the holes in it so I will mount the button in the left outer most hole for activation..
I am truckless..
Re: Line Locks
[Re: 340SHORTY]
#1465065
07/08/13 11:37 PM
07/08/13 11:37 PM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
I would try to install the the line lock button on the shifter if it's primarily for hill holding...jmo.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
Re: Line Locks
[Re: 340SHORTY]
#1465067
07/09/13 01:04 PM
07/09/13 01:04 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Putting the button in the wheel will be a pain.I know.Had it there on my 65.Every time you make a turn it wraps around the TS arm.It finally broke the wire at the button.I had a plate made up for my Pistol grip.It worked but was a pain to power shift.With the stock stick its easy to attach.My lock is mounted at my master.Been there for 5 or 6 years and no problems.Rocky
Chrysler Firepower
Re: Line Locks
[Re: 76dodgeboy]
#1465070
07/10/13 09:04 AM
07/10/13 09:04 AM
therocks
Niles , Ohio
I tossed the bracket I made for my PG.Its buried in the garage somewhere.Ive thought about getting one of the Hurst PGs with the button and retapping it to fit my stock 65 stick.Someone was supposed to make a top with button for the factory PG.Ive been looking for one for years.That would be the ticket.Rocky
Chrysler Firepower
Re: Line Locks
[Re: 340SHORTY]
#1465073
07/16/13 02:14 AM
07/16/13 02:14 AM
Posts: 256 libby mt
lifted85
libby mt
hey 340 shorty what if ya add a floor switch? or if you don't have a horn, use your horn as the button seen it done in a old skylark.
drive fast, drive hard, DRIVE MOPAR
Re: Line Locks
[Re: lifted85]
#1465074
07/16/13 02:57 AM
07/16/13 02:57 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Cant use the horn button.. It goes BeepBeep when you push the button twice..
I am truckless..
Re: Line Locks
[Re: lifted85]
#1465076
07/17/13 12:23 AM
07/17/13 12:23 AM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I have used a micro switch from radio shack attached to the shifter stem just under the handle with a home made bracket. I used my pinky finger to operate it. I used coiled wire down to the boot, and then under the carpet to the solenoid and power source. My
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
