74 B body- Will the engine & trans install together? #1465005
07/08/13 08:47 PM
07/08/13 08:47 PM
A certified culture free zone.
74RALLYE Offline OP
74RALLYE  Offline OP
I'm wrapping up a 4sp conversion to my 74 Charger and I want to install my 440 with the 4sp attached but I don't think it will work out without the front end raised up a couple of feet. Anyone have experience doing this with a 73-74 B body?
Re: 74 B body- Will the engine & trans install togather? [Re: 74RALLYE] #1465006
07/08/13 08:56 PM
07/08/13 08:56 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
The torsion bar x member will be in the way unless you remove it.
Re: 74 B body- Will the engine & trans install togather? [Re: MPerry] #1465007
07/08/13 10:02 PM
07/08/13 10:02 PM
74RALLYE Offline OP
74RALLYE  Offline OP
Are you referring to the transmission mount cross member? I thought the torsion bar cross member followed the floor pan.
Re: 74 B body- Will the engine & trans install togather? [Re: 74RALLYE] #1465008
07/08/13 10:13 PM
07/08/13 10:13 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
No the trans x member is easily removable. There is a separate piece that bolts on the back of the isolated k member for the t bars.
Re: 74 B body- Will the engine & trans install together? [Re: 74RALLYE] #1465009
07/08/13 10:33 PM
07/08/13 10:33 PM
FL
74-440Charger Offline
FL
Mine is auto, but hands down its better with them bolted together. Drop the trans cross member and pull the torsion bars...a bit of work but it will be worth it, especially if your installing headers.
