Are you talking about the metal collar that rotates or the rubber seal that the filler neck goes through? As I recall the same rubber seal number was used for years, when I replaced the tank on my '64 Polara the seal was the same up to the early 70's. As to the pickup, do you need the filter sock or the actual metal tube? I made a 3/8" pickup for my Polara before they were repoped and the filter socks are still available in 5/16" and 3/8" sizes.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
