Instruction Sheet For Plug and Play Elec Dist Firecore #1464364
07/07/13 09:32 PM
07/07/13 09:32 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
I am ready to order one of these but would like to see what is involved in setting the advance curve. Cant seem to find any details in some of the other posts about them.
Re: Instruction Sheet For Plug and Play Elec Dist Firecore [Re: Belvedere1] #1464365
07/07/13 09:49 PM
07/07/13 09:49 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There is no instruction sheet that I know of so far.What type of curve do you need? These units run pretty good with the springs already installed and most of the time you only need to adjust is total mechanical advance with Phillips screwdriver. If you have ever changed the springs on a Mopar distributor you can work on this one.
Gus
64 Plymouth Savoy
Dana 60
Re: Instruction Sheet For Plug and Play Elec Dist Firecore [Re: fourgearsavoy] #1464366
07/07/13 10:04 PM
07/07/13 10:04 PM
Phoenix, AZ
Phoenix, AZ
Mainly just adjusting the mechanical advance. I have changed the springs and set the slot length in the advance plate on the Mopar distributors. I need 20 deg intital and 16-18 mech. So I assume that adjusting the Phillips screws is comparable to dialing in the slot length in the advance plate on the Mopar distributors?
Re: Instruction Sheet For Plug and Play Elec Dist Firecore [Re: Belvedere1] #1464367
07/07/13 10:25 PM
07/07/13 10:25 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I got a instruction sheet with my..I bought it though summit..a lot of adjustment there. I am running mine lock out.
Re: Instruction Sheet For Plug and Play Elec Dist Firecore [Re: Belvedere1] #1464368
07/07/13 10:39 PM
07/07/13 10:39 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Go to Mopar Muscle's website and look at my article," Distributor Testing Evenly Distributed "
There is a picture of the mechanical advance with everything else removed so you can see it.
Keith
Re: Instruction Sheet For Plug and Play Elec Dist Firecore [Re: Dunnuck Racing] #1464369
07/07/13 11:21 PM
07/07/13 11:21 PM
Phoenix, AZ
Phoenix, AZ
Ok, I took a look at those pics. The springs look pretty straightforward as far changing those.
Re: Instruction Sheet For Plug and Play Elec Dist Firecore [Re: Belvedere1] #1464370
07/07/13 11:36 PM
07/07/13 11:36 PM
Rittman Ohio
Rittman Ohio
I would just adjust the mechanical first.I have the tall mechanical race unit in my car and I only needed to limit the total advance 10 degrees my base is 22 and 32 total. Took me about 5 minutes to dial it in
Gus
64 Plymouth Savoy
Dana 60
Re: Instruction Sheet For Plug and Play Elec Dist Firecore [Re: Belvedere1] #1464371
07/08/13 06:26 PM
07/08/13 06:26 PM
Easton, Minnesota
gpuller Offline
gpuller  Offline
Easton, Minnesota
Yes, all you have to do is loosen the screws and change the slot length. I just put a plug and play Firecore in my Charger a few weeks ago. Replaced the old MP unit. Ended up with 25deg initial and 36 total, no vac advance hooked up.
440 with 284/.484 purple shaft.
