70 e body grounds #1464141
07/07/13 06:27 PM
07/07/13 06:27 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
How many ground locations on a 70 e body? I have two grounding points. One is the negative battery cable to engine block and the other is the pigtail from the negative battery cable to the radiator support. I think there should be more.
Re: 70 e body grounds [Re: RROD] #1464142
07/07/13 06:31 PM
07/07/13 06:31 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I believe that's it just the radiator support.
Re: 70 e body grounds [Re: RROD] #1464143
07/07/13 10:17 PM
07/07/13 10:17 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Headlight harness will be grounded around the rad support area.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 70 e body grounds [Re: RROD] #1464144
07/07/13 10:19 PM
07/07/13 10:19 PM
Kirkland, Washington
Pacnorthcuda Offline
Don't forget the engine-to-firewall ground strap.
Re: 70 e body grounds [Re: Pacnorthcuda] #1464145
07/07/13 10:25 PM
07/07/13 10:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
not used on 70-71 E body
Should be a ground wire for the steering column to dash frame, some use a ground wire from the drivers tail light to the side marker
Re: 70 e body grounds [Re: gtx6970] #1464146
07/08/13 01:09 AM
07/08/13 01:09 AM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Will the parts or service manual show the locations of these grounding points? Need pictures.
Re: 70 e body grounds [Re: RROD] #1464147
07/08/13 04:36 PM
07/08/13 04:36 PM
Your dash frame needs to be grounded where it bolts in.
