Re: 1970 Exhaust Manifolds
[Re: B5Superbird]
#1464096
07/07/13 07:28 PM
07/07/13 07:28 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I want to restore the exhaust manifolds on my Superbird. What is the best way to do this? What is the best product to use on them to make them look the most correct?
If "correct" is what you want, then rust is what you'll need as factory manifolds had no protective coating, engine paint overspray was about it, and it didn't last long, so they ended up looking ugly in short time,...IMHO, if your castings are very nice and pit free, I'd have them ceramic coated, Fireball coatings does a very nice job, they have a very natural coating for a new cast look, you can then decide if you want to add the "overspray" appearance to them for a much more original appearance, I've used Fireball coatings after Alan Galant (barrelcuda) recommended them to me, and they're right in your backyard in Erin, Ontario, a set of manifolds will run $250-$350 depending on size, do them once, do them right
Mike
Fireball Coatings 519-833-2628
[Re: topside]
#1464099
07/07/13 08:45 PM
07/07/13 08:45 PM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
Didn't they have that metal "stove" on the left manifold? My '70 383 4-bbl did, and as I recall it was originally black. Pre-'70s don't have them.
Yes, you are right. 383 & 440 4-bbl applications for '70-'71 had the heat stove on the DS manifold. If the car were equipped with a shaker hood, Air grabber or Ramcharger, then the heat stove was omitted.
