Re: best 727 to hunt for
[Re: Adam71Charger]
#1464050
07/07/13 07:03 PM
07/07/13 07:03 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
4-pinion planetaries are highly overrated, it isn't the pinion count that's the weak point it's the splines in the aluminum carrier.
Coming from a C-body is no guarantee, a 383-2 C-body won't have heavy duty parts.
[Re: John_Kunkel]
#1464051
07/08/13 01:11 AM
07/08/13 01:11 AM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I want to make a fun project out of it. I ordered the 'Torqueflite A-727 Transmission Handbook' and I have about 500 to spend on the upgrades and rebuild. I've read some other posts of yours on torqueflights, do you rebuild them? I have access to a cheap 1975 motorhome 440/727, and I think Ill start with that one if its in good shape, or I could take the 727 out of my 72 newport 400-2bl
[Re: Adam71Charger]
#1464052
07/08/13 02:19 AM
07/08/13 02:19 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Some of the MH BB 727s have a short tailshafts and the tranny mount locates differently.. Thay also have little brake drums mounted on the rear. They dont have slip yokes either..
I am truckless..
[Re: 71yelladustr]
#1464053
07/08/13 10:28 AM
07/08/13 10:28 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Big block and motorhome transmissions will have the more heavy duty parts installed like you are wanting.
But a motorhome transmission will require a 2nd parts trans , it is not a bolt in to a passenger car.
