Brake pedal doesnt return #1463985
07/07/13 02:53 PM
07/07/13 02:53 PM
Newtown, CT
70ucode Offline OP
70ucode  Offline OP
Newtown, CT
70 Cuda with factory power front discs. Car sat along time. Brakes look like new. For the first 10 miles or so the brake pedal won't return on its own. I have to put my foot under and pull up. After a long ride they work fine. Plenty of vacuum. Any thoughts? Booster? Master? Calipers? Weird how it works after a while. Thanks John.
Re: Brake pedal doesnt return [Re: 70ucode] #1463986
07/07/13 03:09 PM
07/07/13 03:09 PM
Andrewh Offline
Andrewh  Offline
pull the vacuum to the booster.
try again, see if it still does it.
sticky valve in the booster could cause it too.
had one that pulled the pedal down as I drove.
It will be much harder to brake so don't drive too far or too fast to try this.
Re: Brake pedal doesnt return [Re: Andrewh] #1463987
09/08/13 07:28 PM
09/08/13 07:28 PM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
Did this get resolved? Same issue.
