Re: 64 Savoy electric problem PLEASE help !!
[Re: Supercuda]
#1463857
07/07/13 10:45 AM
07/07/13 10:45 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Where do you have the large wires for the box attached?They should go to the battery.Also make sure the dist hole in the block is clean and not full of paint.My 440 would not run till I cleaned the hole for a good ground.When it quits are you getting spark from the coil?Rocky
Chrysler Firepower
[Re: biged1932]
#1463858
07/07/13 11:06 AM
07/07/13 11:06 AM
RapidRobert
Might be the MSD dist. You said restoration so it's a SB I'm assuming. If a std electronic dist will trigger the MSD system & you have a SB electronic dist handy you could sub it in. When it dies is this at speed or at idle after 10-20 minutes of driving? & when you start it back up after it dies does it take another 10-20 minutes before it dies again EDIT on the chance that it is a partly plugged carb idle circuit you might afix one of those thin red straws to a can of starting fluid & shoot a 2 or 3 second blast into each idle mixture port. count the # of turns to lightly seated & you can easily/quickly return the screws to their previous exact position. As said I'd wanna check for spark when it acts up but it does immediately start back up which is confusing since it'd still be just as hot or almost as hot I would think but as you know electronics are strange. Holler how it goes. I ain't never owned an MSD product (yet) but the moniker the one guy (on here) put on it (Might Sputter & Die) always scared me a bit
[Re: SSAAHemiFan]
#1463861
07/07/13 07:11 PM
07/07/13 07:11 PM
RapidRobert
He tried a 2nd box (6al) but not the dist
[Re: biged1932]
#1463862
07/07/13 07:46 PM
07/07/13 07:46 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Sounds like a fuel vent problem to me Does the engine just die or does it sputter like it's running out of fuel. The fact that it fires right back up rules out the distributor pick up.I have almost the same ignition except I have a Firecore distributor and my 6AL is mounted inside on the firewall too.I had mud dobbers put a mud plug in my fuel vent before and my car done almost the same thing.I changed the fuel pump before I figured it out Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: biged1932]
#1463865
07/08/13 12:24 AM
07/08/13 12:24 AM
RapidRobert
I'd say a loose connection as there is no magic. glad ya got it solved
