Re: 340/904 flexplate
[Re: 71Polara383]
#1463803
07/07/13 01:46 AM
07/07/13 01:46 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
What flex plate is needed to use a 904 behind an external balance 340? Was gonna build a 360 but plans changed. The converter I bought is for external balance small blocks. Its a boss hog 2800 stall for a 904
the amount weight for externally balanced 340 and 360 are different...
can not use a externally balanced converter for a 360 on a externally balanced 340....need to knock weights off converter and get B&M weighted flexplate for externally balanced 340.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
