AC #1463678
07/06/13 08:34 PM
07/06/13 08:34 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
How hard/how expensive is it to put a/c into a non a/c car? I have an E body, 318 engine.
Re: AC [Re: z70dodge] #1463679
07/06/13 08:46 PM
07/06/13 08:46 PM
Andrewh Offline
Andrewh  Offline
several companies have complete kits. classic auto air and vintage air are the 2 big ones.
buchillon(sp) is another that makes the underhood parts.
ebodies are popular enough no cutting is required.
should run you around 1200-1500 depending on a few things. but that is soup to nuts, nothing else to nickle and dime you.
kits start at about 1k.
Re: AC [Re: z70dodge] #1463680
07/06/13 09:04 PM
07/06/13 09:04 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
What do guys do when there cars have no dash vents? Just at your feet and defrost?
who is that guy?
Re: AC [Re: Brian_wo] #1463681
07/06/13 11:28 PM
07/06/13 11:28 PM
Andrewh Offline
Andrewh  Offline
no, they make vents that bolt to the underside of the dash, to point it up to your face or body.
or others have changed to a/c dashes. just depends on how much you want to spend.
I even recall seeing one where the guy cut out the dash to mount vents.
Re: AC [Re: Brian_wo] #1463682
07/07/13 03:36 PM
07/07/13 03:36 PM
USA
Z
z70dodge Offline OP
z70dodge  Offline OP
Z
USA
Thanks for the tips!
