Overheating? 'Tis the season. Read before posting. #1463496
07/06/13 11:43 AM
07/06/13 11:43 AM
Irving, TX
feets Online tonguue OP
Senior Management
feets  Online Tonguue OP
Senior Management
Irving, TX
I'll turn this into kind of a query so it'll stay in the Q&A forum with all the overheating posts.
If you're running hot and looking for some answers, there are some simple things you can do on your own.
I'm not some all-knowing oracle who can solve the world's cooling problems but with basic info I (as well as many others here) can knock out 90% of them quickly with minimal time and money.
Number one, beyond any question, is to get a temp gun. Period. End of sentence.
Harbor Freight has them on sale for $37.
http://www.harborfreight.com/infrared-thermometer-with-laser-targeting-non-contact-69465.html
Those things work great. Sure, they may be off a degree or two but who cares? You're looking for big swings in temperature and they will get the job done.
If you don't have one you obviously don't want to know why your car is overheating. Get one. Now. We'll wait for you. This thread should still be around when you get back from the store.
Don't have overheating problems? Go get one anyway.
If you have real temperatures of different parts of the cooling system it's really easy to track down any problems. Without those temps you're just guessing.
Use the temp gun to check the radiator temperatures. if your cooling system is working properly you will have about a 30 degree difference between the radiator inlet and outlet. If that isn't the case you have a problem up front.
Scan the radiator across the core. If there are cold spots you know the radiator is plugged and needs attention. Obviously, the radiator will be cooler where the fan is drawing air. If the fan clutch is slipping or the fan is too weak then you will not see a substantial drop in temperature in front of the fan.
Here's a BIG hint: A proper shroud will pull air from all parts of the radiator, not just the bit right in front of the fan. That's why shrouds are important.
You can use the temp gun on the temperature sending unit to confirm the gauge reading.
It can also spot colder spots on the engine if you have a misfire or dead hole. The temp will be cooler on that part of the exhaust manifold too.
You can shoot the cylinder heads to see if one side is cooler than the other. That would indicate problems inside the engine.
Trouble with the A/C? You can check air temperatures at the registers as well as line temperatures under the hood.
Don't have a candy thermometer? You can use the temp gun to monitor you cooking oil when frying hush puppies.
Back to trouble shooting...
If the temperature of the hoses is drastically lower than the temperature of the block and heads then you're not moving water. Check the lower hose to make sure it's not getting sucked closed when the engine is revved. Sometimes it's hard to see so you need to lay hands on it. Just don't get your arm caught in the belts or fan.
If the upper hose is drastically cooler than the thermostat housing and top of the water pump you know the thermostat isn't opening.
Engines without thermostats will sometimes move coolant too quickly. That doesn't allow the coolant to stay in the radiator long enough to lose temperature. You can spot that when the radiator temps drop smoothly across the radiator but don't change by more than 15 degrees or so.
If you want to know why something doesn't work you need to find out what part isn't working. When that's a cooling system you must know the temperatures you're dealing with. Without that basic info it's all guesswork.
Have a problem? Want help?
1) Get a temp gun.
2) Get numbers.
3) Get back with us.
Now, to form some sort of question to keep this in the appropriate forum...
What other tools do you guys use to diagnose cooling problems?
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463497
07/06/13 12:47 PM
07/06/13 12:47 PM
A 6" section of metal rad hose spacer with the rolled edges on the end for $9.95 from www.speedwaymotors.com & drill a hole & add a tire valve stem then with 2 piece of junk rad hose install this setup in place of the top rad hose & pump it up to 15 lbs & see if it holds. Done when hot & let it sit overnight if need be to check the pressure drop. If it is leaking it could be to the outside or internally & to see if it's leaking into the combustion chamber (as you know it's the other way around the CC leakes into the cooling system)I take off the stat housing/stat/fanbelt & with the coolant to the neck of the rim start the eng & let it idle from cold & gun the eng repeatedly for a minute & see if it starts to geyser up or show bubbles. If the impeller ain't turning there should be a dead calm with no turbulence unless combustion gasses are getting by the head gasket/cracked head/block. Yes I want to get a temp gun. Thanks for the reminder Feets. How'd things turn out with your neighbors from Hell
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463498
07/06/13 07:06 PM
07/06/13 07:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
awesome post!
Re: Overheating? 'Tis the season. Read before posting. [Re: mikemee1331] #1463499
07/06/13 08:39 PM
07/06/13 08:39 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
My 69 VW Bug keeps overheating, should I flush my radiator?
great post kevin.
**Photobucket sucks**
Re: Overheating? 'Tis the season. Read before posting. [Re: 70Cuda383] #1463500
07/06/13 09:02 PM
07/06/13 09:02 PM
Irving, TX
Senior Management
Senior Management
Irving, TX
Flush both radiators, change your coolant, turn the thermostat right side up and toss the factory water pump in the trash.
My parents once belonged to a VW club. I drove the hot rod to one of their meetings. When the club president asked what kind of car I had I told 'em it was a 1965 water cooled.
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463501
07/06/13 10:14 PM
07/06/13 10:14 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Must be a slow day in Irving.
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463502
07/06/13 10:18 PM
07/06/13 10:18 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
A pressure tester is a good thing to have for various things. Helps to find leaks, first and foremost, tests caps, etc. I've also used it as an aid to double check repairs before the coolant gets hot again. Available basically anywhere.
http://www.summitracing.com/parts/snn-12270
'71 Duster
'17 Ram 1500
Re: Overheating? 'Tis the season. Read before posting. [Re: RMCHRGR] #1463503
07/06/13 10:54 PM
07/06/13 10:54 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
Just a tip when you are using your IR gun. If you are taking a reading on something shiny "Chrome T-stat housing or that new brass temp. sending unit" , put a piece of masking tape on the spot. Shiny parts will throw off the reading. Just my
Scott
Re: Overheating? 'Tis the season. Read before posting. [Re: 6PakBee] #1463504
07/07/13 12:21 AM
07/07/13 12:21 AM
Irving, TX
Senior Management
Senior Management
Irving, TX
That was meant as a helpful thing, not a rant.
It's summer and there have been a number of overheating topics already. Very few of them have touched on the basic step one stuff I described above. The common response is a jump to some sort of conclusion. Often, someone is asked if they have verified the temperature gauge accuracy. That's part of what you can do with the temp gun.
Maybe someone can read the top post, take the suggested steps, and solve their problem on their own without having to wait for responses from people scattered across the country who can't lay hands on the car.
For the record, yes it was a slow day in Irving. I managed to paint/dye/whatever the door trim panels for the hot rod. That's more progress than I've made in a couple months.
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463505
07/07/13 03:34 AM
07/07/13 03:34 AM
hooziewhatsit Offline
How big of an area does that IR gun read? I have a different one that reads in a 90* cone ie, at 5" away, it averages the temperature over a 5" diameter circle.
If it only reads the laser point, I'll have to pick one up just to have...
Re: Overheating? 'Tis the season. Read before posting. [Re: hooziewhatsit] #1463506
07/07/13 04:11 AM
07/07/13 04:11 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Nice thread feets!
Re: Overheating? 'Tis the season. Read before posting. [Re: hooziewhatsit] #1463507
07/07/13 11:52 AM
07/07/13 11:52 AM
Irving, TX
Senior Management
Senior Management
Irving, TX
This one says:
Distance-to-spot ratio: 8 to 1
That means at 8 inches away it'll measure a 1 inch area.
16 inches away it'll measure a 2 inch area.
Many of them tell you the range with a graphic on the side of the unit.
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463508
05/21/14 06:53 PM
05/21/14 06:53 PM
Irving, TX
Senior Management
Senior Management
Irving, TX
A bump for the 2014 overheating season.
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463509
05/21/14 07:04 PM
05/21/14 07:04 PM
Kirkland, Washington
Pacnorthcuda Offline
AND determine if its overheating at idle while the car is not moving, or at speed. Or possibly both!
Re: Overheating? 'Tis the season. Read before posting. [Re: Pacnorthcuda] #1463510
05/21/14 07:26 PM
05/21/14 07:26 PM
Irving, TX
Senior Management
Senior Management
Irving, TX
I nailed a stuck thermostat on the side of the road on the 2012 Power Tour using my IR temp gun.
It's pretty easy to troubleshoot once you have something like that working for you.
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463511
05/21/14 07:28 PM
05/21/14 07:28 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
I'll point out that 99% of the "defective" thermostats returned (by parts stores or new car dealers or wherever) have nothing wrong with them.
It is also physically impossible to have a thermostat that "sticks" once in a while.
Steve
Someday I'll have another C-body.
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463512
05/21/14 07:32 PM
05/21/14 07:32 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I held off buying an IR Temperature gun because i could not find one that would read within ten degrees of true.
Last year when it was on sale I tried this one:
http://www.sears.com/extech-1400-degree-...mp;blockType=G3
I like it because it comes with a high temperature Type K thermocouple touch probe too, and you can adjust the "Emissivity" of the IR spot so that it will read correctly by touching an easy to get at spot with the probe, then adjust the Emissivity setting so that the IR spot reading matches the probe.
Best of both methods.
Re: Overheating? 'Tis the season. Read before posting. [Re: 360view] #1463513
05/21/14 08:05 PM
05/21/14 08:05 PM
Irving, TX
Senior Management
Senior Management
Irving, TX
I don't worry much about the absolute value given by the IR gun. Assume it's wrong.
I care about the consistency of the value.
If it shows 180 degrees when the object is 170 degrees it's not that big of a deal. This assumes it shows the temp to be 180 degrees every time the object is 170 degrees.
If it shows the same difference in temp it's good enough.
Shows 190 when object is 180.
Shows 200 when object is 190.
And so on.
That's all you need.
A radiator should have about a 30 degree drop in temp from input to output. That's the concern. Finding differences in temperature.
I know my IR gun is off but it showed me the big temp difference between the water pump housing and the upper hose. BINGO! Thermostat wasn't opening. Overheat problem solved in seconds. Power Tour resumed.
The same car had an issue with overheating at idle and I fixed it with a large clutch fan. The car was using the stock fixed fan and no shroud. It simply wanted more air at idle.
The father and son team who drove that 71 Charger in 2012 came back for the Power Tour in 2013. They still had my clutch fan in place.
- Stu Harmon
Re: Overheating? 'Tis the season. Read before posting. [Re: feets] #1463514
05/24/14 01:15 PM
05/24/14 01:15 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
OK. I'm back from the store. What'd I miss?
(Just joking around) Good Post!
Re: Overheating? 'Tis the season. Read before posting. [Re: patosmith] #1463515
05/24/14 01:21 PM
05/24/14 01:21 PM
which one did you get I want one that's adequate to take care of business (just eng/rad temps) with out bells and whistles that I will not use (or afford). Never owned one so a newbie here
