1965 valiant rad......
#1463417
07/06/13 02:54 AM
07/06/13 02:54 AM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
ordered this radiator for my engine, fits perfectly, just that is quite thick and i still need to add the custom shroud and fans.
Iam not really sure what is the best option here, to shroud or not to shroud, pusher or puller fans....mandrel is real close but it can work with a not so tick shroud, in the other hand i can gain some space modifing the radiator frame support.
Need some ideas as to what I can do, ideas or thoughts?
Re: 1965 valiant rad......
[Re: SB449VALIANT]
#1463422
07/06/13 03:19 AM
07/06/13 03:19 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I've been running that radiator on the street for many years. Of course a shroud would be best but not needed in all applications. Puller fans and shroud are not too hard unless you have some special situation? I can take some pics of my home fabbed setup if it might help?
[Re: kotacars]
#1463426
07/06/13 01:24 PM
07/06/13 01:24 PM
SB449VALIANT
Mcallen, TX
If this is a drag car why are you using that radiator?
Well .....we want the engine to be as cold as possible to produce maximum horse power, also at 14.5 is easy to have detontion with bad gas,etc...i see alot of race cars using this tiny radiators, that Scares me!!! Thanks
[Re: Thumperdart]
#1463428
07/06/13 05:02 PM
07/06/13 05:02 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Check out Derale. They have some high output dual setups that flow 4000 cfm.
Mopar to the bone!!!
