Windage tray for 500" motor
#146321
11/05/08 11:46 PM
11/05/08 11:46 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
Is this a decent tray for a guy on a low budget. I have a low deck with a 4.15 crank, it's suppose to fit but I want to make sure before I go buy one. Seems like a great price and comes with gaskets. My current MP tray doesn't fit on this motor but it worked fine on the low deck 432 stroker.
Re: Windage tray for 500" motor
[Re: ProSport]
#146322
11/06/08 12:02 AM
11/06/08 12:02 AM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I was just looking at the 440 Source tray and it looks good too when you factor in "good" gaskets it might be a better deal. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#146324
11/06/08 02:14 AM
11/06/08 02:14 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
The problems arise with different styles of pick-up tubes......you may still have to hack out a relief in the windage tray for the bend in the pick-up tube (If it has a few bends). I used a Mopar 4.15 tray with the 440 source 7 quart pan and pick-up.....had to cut an oval area out of the tray to get everything to fit. Works OK....just a little bit of added work I hadn't planned on. A box of Bud's took care of that!!
[Re: ProSport]
#146326
02/13/09 04:27 PM
02/13/09 04:27 PM
ProSport
Akron, Ohio
Well, I gotta bring up this old thread cuz I was gonna get the Mopar Performance P5007345 tray today at Summit but it's out of stock.
They have the Milodon in stock, does it fit a 500" low deck for sure? I'm using external oiling.
I'll check 440source again too.
[Re: challenger1320]
#146328
02/13/09 04:49 PM
02/13/09 04:49 PM
ProSport
Akron, Ohio
Does the 440Source tray come with 2 gaskets?
[Re: ProSport]
#146331
02/13/09 05:58 PM
02/13/09 05:58 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
The Mopar brand stroker windage tray will hit the front of the stock oil pans, even some of the deeper aftermarket oil pans that use a stock Mopar oil pan core to start with I still have some of the billet .250 oil pan spacer that allow you to use a stock windage tray between the spacer and the oil pan with a 4.375 stroker crank with Mopar size rods PM me if interested ($75.00 each plus shipping)
[Re: ProSport]
#146332
02/13/09 06:33 PM
02/13/09 06:33 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
Get the milodon stroker tray .
What size rod journals ? Side note I have the non stroker milodon tray in my 3.9 stroke engine using 2.2 big end rods .
[Re: Cab_Burge]
#146333
02/13/09 10:27 PM
02/13/09 10:27 PM
Posts: 3,150 Central NC
gch
Central NC
I bought one from cab a while back.I have not used it yet but I can tell you it is a quality piece.I look forward to using it when my 505 finally comes together.
