Elec. Cooling Fans? BB Overheating issue
#1463188
07/05/13 04:44 PM
07/05/13 04:44 PM
Posts: 624 Modesto CA
BFASTER
Modesto CA
My street 440 in the Super Bee is using a flex fan with a half-shroud and 195° stat and it tends to overheat rapidly, especially in traffic, in temps above 90...which is pretty much all summer long here. Coolant is fine, rad is clean, no leaks. I'm wanting to use an electric fan set-up but was hoping for some input here. What do you use?, and how hot does it get: motor and/or ambient air? It's Any input would be appreciated.
1969 Dodge Super Bee Hardtop
2007 Nissan Altima 3.5SE
Re: Elec. Cooling Fans? BB Overheating issue
[Re: BFASTER]
#1463189
07/05/13 05:08 PM
07/05/13 05:08 PM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
I would look for a good pusher fan if you want to keep the flex fan but they don't get the job done...I would get that HHR electric fan ..very strong ,quiet and cheap,,moves a lot of air....Think I paid around 59 $ for mine...as it's an oem fan it is dependable and is quiet and has it's own shroud.I was stuck in traffic one hot summer day for over an hour,,, never ran past t-stat temp.... the 195 t- stat is too high,,go 180. The HHR worked well for me while it was still 440 cid...started to run hot once I went 493 cid stroker motor..then I went to a 28 inch rad and dual fans from a full size Chrysler ...
[Re: BFASTER]
#1463193
07/05/13 09:27 PM
07/05/13 09:27 PM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Sounds like a good plan. BTW, when I had that chrome half shroud, I tried to make it into a "full" shroud by completing the circle with very thin sheetmetal. That didn't work either, I think because of lousy sealing between the shroud and radiator, and possibly the fan being too small within the shroud, so it didn't have to pull air through the radiator. So, just in case you were tempted to try a shortcut, been there done that
[Re: Exit1965]
#1463194
07/05/13 09:36 PM
07/05/13 09:36 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The only flex fan that I have ever had good luck with was the factory fan on my old 72 Mach 1. The aftermarket 1s are garbage and also dangerous. Ive seen good results with that 5 blade MP fan..
I am truckless..
[Re: 340SHORTY]
#1463195
07/05/13 10:22 PM
07/05/13 10:22 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I run a stainless flex fan from Summit.My 440 is built radical and never gets over 185 even in the 90s.It runs a untouched 65 C body 22 inch rad with the small factory shroud.I even run underdrive pulleys.My kids 62 300 413 also runs a factory rad no shroud as from the factory.He has UD pulleys and flex fan also.It never gets over 190.My fan is probally over 20 years old and no problems even spinning it to 7200 at the track.My son races the 62 also.Only fan I ever had break was a factory steel one and that was 40 years ago.We both run 180 stats.No need for anything higher.Rocky
Chrysler Firepower
