Holley 750 DP question #146314
11/05/08 11:44 PM
11/05/08 11:44 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
I bought a Holley 750DP with the choke tower milled off.
Is there any way to confirm this is really a 750?
What would be the performance differences between a regular 750DP with the choke tower, with the choke tower removed, and Proform 750 main body (doesn't have the choke tower)?
Thanks.
Greg
Re: Holley 750 DP question [Re: GregY] #146315
11/06/08 12:43 AM
11/06/08 12:43 AM
Is there any way to confirm this is really a 750? Thanks. Greg
measure the bore diameters. I have no actual ex with proform main bodies but what I have read posters have been happy with them
Re: Holley 750 DP question [Re: RapidRobert] #146316
11/06/08 08:16 AM
11/06/08 08:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
proform mainbodys are milled nice to increase airflow..or direct it, they also have adjustable air bleeds. They flow about 823-830 cfm on a 750 DP base plate. The Holley should have a part number on the side. 4150?? get the part number and google it
Re: Holley 750 DP question [Re: Mr.Yuck] #146317
11/06/08 08:56 AM
11/06/08 08:56 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
On my other Holley carbs, the part number is on the choke tower. I didn't really see any other part numbers on my used 750 with the tower milled off.
Re: Holley 750 DP question [Re: GregY] #146318
11/06/08 09:51 AM
11/06/08 09:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my 750 HP doesn't have a tower so it's on the main body.
Re: Holley 750 DP question [Re: Mr.Yuck] #146319
11/06/08 10:44 AM
11/06/08 10:44 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Regular DP would have it on the tower, if its milled off you have to measure the venturi diamters.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Holley 750 DP question [Re: CJK440] #146320
11/06/08 05:21 PM
11/06/08 05:21 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Do you know what they should be? I guess I can probably find it somewhere.
