Engine Builders #1463138
07/05/13 03:41 PM
07/05/13 03:41 PM
MR_P_BODY Offline OP
I have a Clevite bearing(mains) with two sets of numbers
MB 2035 P-U and the other is MB 2283 P.... its a .010
under set but I cant find a listing on it anymore..
is there another number for this bearing now days..
this bearing looked great and has lasted a LONG time
so I'd like to use the same part.... any help would
be great
Re: Engine Builders [Re: MR_P_BODY] #1463139
07/05/13 06:30 PM
07/05/13 06:30 PM
Re: Engine Builders [Re: MR_P_BODY] #1463140
07/05/13 06:48 PM
07/05/13 06:48 PM
Delray beach, Florida
P
Performance Only Offline
P
be great
MB2035P is part of set # MS-540P
MB2283P is part of set # MS-1344P
machine shop owner and engine builder
Re: Engine Builders [Re: Performance Only] #1463141
07/05/13 07:21 PM
07/05/13 07:21 PM
be great
Dan. what I see is one is for a 318 the other is for
a 340.. we know they use the same crank... so WHICH
would you suggest... this is going in my 395 ci
for the Rampage for drag week and running around town
thanks for the reply
EDIT
All set ... thanks Dan
Re: Engine Builders [Re: MR_P_BODY] #1463142
07/07/13 04:43 PM
07/07/13 04:43 PM
Well ... more problems... the rod bearings I got are
Clevite CB481P... the set I got from Summit are the
SAME part number CB481P but they dont have the bevel
for the radius side... any thoughts... I know I can
bevel these but I thought I bought these with it..
its a .020 under bearing
Thanks guys
Re: Engine Builders [Re: MR_P_BODY] #1463143
07/07/13 05:57 PM
07/07/13 05:57 PM
From what I see I must have cut the bevel on them..
I cant find a .020 under chamfered bearing at all
for a mopar rod
Re: Engine Builders [Re: MR_P_BODY] #1463144
07/07/13 06:40 PM
07/07/13 06:40 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Try looking for any rod bearing marked N in the number suffix IE: HND heavy duty,narrow,dowel hole.P is standard width,H is heavy duty(usually tri metal),M is Micro,D is dowel hole,V for after market cranks with 2.375 journal in blown applications.Most all after market ,radiused cranks use the N or narrow bearings.It's almost impossible to find the old champhered bearings.
Re: Engine Builders [Re: B G Racing] #1463145
07/07/13 08:25 PM
07/07/13 08:25 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
The narrow bearing is a cb481hn.
Re: Engine Builders [Re: DavidDean] #1463146
07/07/13 08:37 PM
07/07/13 08:37 PM
Thanks.. I'll have to write that down... I already cut
the champer on this set.. I have a old rod set up to
do it.. I just thought I bought this set already to go..
but even looking closely at them I should have added
more ... so I did on this set .. I'll finish this short block
tomorrow
