Re: Adapting a 440 MSD Distributor to a 400 Block?
[Re: AndyF]
#1463125
07/05/13 03:42 PM
07/05/13 03:42 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
That is kind of a trick question.
Now I am confused....can you elaborate on that sir?
I was hoping to gain some height using a 440 distributor in a 400 block with a spacer. Am I missing something here (like usual)?
Moparteacher - I will keep that in mind. I think the spacers are still around for sale...
[Re: Jeremiah]
#1463128
07/05/13 08:41 PM
07/05/13 08:41 PM
Posts: 31,052 Oregon
AndyF
It is a trick question because Mopar Performance has been making RB to B distributor adapters for 40 years. The trick part of the question is that those adapters do not fit a MSD distributor.
[Re: AndyF]
#1463131
07/25/13 02:57 AM
07/25/13 02:57 AM
Posts: 95 NW INDIANA
ta3834bbl
NW INDIANA
What is different about the MSD dist that it won't fit? I have been using a 440 dist in my 383 for 25 years and was thinking about upgrading to an MSD. now I'm confused....
67 Dart GT Convertible 273 68 Barracuda 383 68 Roadrunner 383 4spd 1 '01 Ram 2500 4x4 diesel 2 '02 Rams 1500 4x4's 4.7s 3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4 Oh, and a 03 Grand Cherokee and an '00 durango
[Re: ta3834bbl]
#1463132
07/25/13 07:53 AM
07/25/13 07:53 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
The MSD distributor has a bearing in the housing at both ends of the shaft so it is larger , all you need to do is have the ID of the adapter opened up , 10 mins on a lathe , if that long .
[Re: ta3834bbl]
#1463134
07/25/13 11:15 AM
07/25/13 11:15 AM
Jeremiah
Rogue River, OR
I am going to use the taller RB distributor in a B (in this case 400) block to gain more clearance between the cap and passenger side valve cover. Hope that makes sense.
[Re: Sinitro]
#1463135
07/25/13 11:19 AM
07/25/13 11:19 AM
Jeremiah
Rogue River, OR
If running an N96 air grabber, suggest you check its clearance...
Just my $0.02...
I appreciate the tip. My "air grabber" is two 1050's and an Indy tunnel ram.
[Re: Jeremiah]
#1463136
07/25/13 01:14 PM
07/25/13 01:14 PM
ta3834bbl
NW INDIANA
Thanks, I got that part, doing the same thing ( 440 dist in a 383 ) , I was confused about the msd not fitting in my old adapter . I am with the program now
[Re: JohnRR]
#1463137
07/25/13 01:26 PM
07/25/13 01:26 PM
Posts: 10,041 MN
JERICOGTX
MN
That is correct. While it's on the lathe have it cut for a O ring also so it seals. Thanks to HEMI Joel for turning mine down.
