Engine Vacuum? #1462697
07/04/13 03:14 AM
07/04/13 03:14 AM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Hi All,
How long is a piece of string?
Or, is my vacuum reading in the appropriate range?
Engine is a E-headed, 10.4:1 505", 0.587/0.593 287/294 cam, M1 intake and 1050 Dominator (8896).
Carb specs:
78/88 Jets
Transfer slot restrictor: 0.055"
PV channel restrictor: 0.089"
Idle feed restrictor: 0.040"
Idle air bleed: 0.082"
Main air bleed: 0.028"
I can't find a record of the timing, but I set it to whatever is in the archives (18 BTC at idle, 32 total in all by 2400 rpm, or something like that).
It's pulling about 8" Hg on the mity vac, with a bit of flutter in the needle. Does that seem about right to you with that cam and set up?
Re: Engine Vacuum? [Re: Damned67] #1462698
07/04/13 07:13 AM
07/04/13 07:13 AM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Actually, I need to double check my timing. I had a carb issue 12+ months ago, and moved my timing to 16 BTC. I can't remember if I retimed the car (although, I'm pretty sure I did)... I should also check the valve lash while I'm at it.
Re: Engine Vacuum? [Re: Damned67] #1462699
07/04/13 10:25 AM
07/04/13 10:25 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Is that cam number @ .050 or advertised. What is the cams LSA and where did you install it?
Re: Engine Vacuum? [Re: Dodgem] #1462700
07/04/13 11:42 AM
07/04/13 11:42 AM
sweden
sshemi Offline
sshemi  Offline
sweden
If that is at 050 its one crazy build!
Re: Engine Vacuum? [Re: Dodgem] #1462701
07/04/13 01:24 PM
07/04/13 01:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That would have to be advertised.................
Re: Engine Vacuum? [Re: Damned67] #1462702
07/04/13 08:35 PM
07/04/13 08:35 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
According to the cam card, the lobe separation is 112.
Lobe centerline is 108/116.
Duration at 50 is listed as 259/266.
I would have thought that I should be pulling 12-15" Hg with that cam. I just don't want to spend time chasing problems that may not exist....
Re: Engine Vacuum? [Re: Damned67] #1462703
07/04/13 11:11 PM
07/04/13 11:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
How big a motor and did you degree the cam??
I would think it would like 28 at idle and 38 all in?
and how low you trying to idle it?
Re: Engine Vacuum? [Re: Dodgem] #1462704
07/04/13 11:42 PM
07/04/13 11:42 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
505" engine.
I can't comment on the cam being degreed, the engine was assembled by a local (and well respected) Mopar/race engine builder.
Idle is around 8-900rpm.
Thanks!
Re: Engine Vacuum? [Re: Damned67] #1462705
07/05/13 12:23 AM
07/05/13 12:23 AM
Az
Crizila Offline
Crizila  Offline
Az
505" engine.
Thanks!
For that size motor I would think it is a little low. Maybe 12" Hg would be more like it.
Fastest 300
Re: Engine Vacuum? [Re: Damned67] #1462706
07/05/13 01:08 AM
07/05/13 01:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you sure you have all the vac ports plugged..
that vac is low... it should be in the 14-15 range
unless the valves arent sealing(or bouncing alot)
Re: Engine Vacuum? [Re: MR_P_BODY] #1462707
07/05/13 02:19 AM
07/05/13 02:19 AM
sweden
sshemi Offline
sshemi  Offline
sweden
If you have 16* initial timing and 800 idle speed, i dont think its very low.
Up timing to 22* and idle speed to 1000 and youll see 12" vac.
Re: Engine Vacuum? [Re: MR_P_BODY] #1462708
07/05/13 05:10 AM
07/05/13 05:10 AM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
My apologies for the lack of info... I haven't really tuned this car in probably 2 years, and it's done probably 10-20 miles in that time. I did rebuilt the carb a year ago.
Plan for tomorrow is to check timing and valve lash, and to go from there. I seem to remember that the engine was once pulling 12-13" Hg, which could be somewhat confirmed by the fact that I put a 5.5" power valve in the carb last year.
I need to go over it all and get all the baseline sorted, before I get to worried about anything....
Re: Engine Vacuum? [Re: Damned67] #1462709
07/05/13 10:21 AM
07/05/13 10:21 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Cool I would definitely go with more initial advance and total 36 to 38 just turning it to 38 total may work wonders. so if you turn it to 24 that should give you 38 total.
Big enough cam you may want the timing to come in sooner it's a try and see from hear.
Re: Engine Vacuum? [Re: sshemi] #1462710
07/07/13 04:14 AM
07/07/13 04:14 AM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Sadly not... That was yesterday's job, including checking the valve lash. Still the same crappy 7-8"Hg, with the needle bouncing around a bit.
Re: Engine Vacuum? [Re: Damned67] #1462711
07/07/13 11:44 AM
07/07/13 11:44 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
often it's tinker tinker tinker.
Re: Engine Vacuum? [Re: Damned67] #1462712
07/07/13 11:52 AM
07/07/13 11:52 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I still think you need more timing at idle.
but first I would check the power valve.
Then you can do this without driving start turning the advance up even as high as 32 or more at 1000 rpm see what it really likes for idle advance. Later turn it back till you can recurve the dizzy if need be.
That's a big enough cam even in a 505 and big cams like lots of idle advance.
I take it you have re set the float bowels?
Re: Engine Vacuum? [Re: Dodgem] #1462713
07/07/13 09:31 PM
07/07/13 09:31 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Hi Dodgem,
I reset the float bowls last year when I rebuilt the carb (or re-gasketed the carb, as it were).
I thought I should double check the levels, but just ran out of time.
I'm somewhat lacking in the tuning area, mostly because I don't touch the car for a year, then forget what I learnt in the past. Indeed, took me ages to lash the valves, simply because it's been so long... and I forgot all my little tricks to getting the awkward plugs out to turn the engine.
And yes, I plan on tossing a different power valve in it.
Anyway, I'll get back to it on the weekend, unless I'm home from work early during the week.
Also, I found this in amongst my PMs from 5 years ago when this engine was first fired up, from the gentleman that spec'd the engine out:
"I would expect about 10-12 inches of vacuum on that combo. what are the idle rpm and timing set at? dominators don't have any vacuum ports so hopefully you drilled in a good spot. that combo should idle around 950 rpm with timing at around 18* btdc.
if those are correct i'd take a look at the valve lash. that cam is 259/266 @ .of with.587/.593 lift on a 112 lobe center. it should have plenty of vacuum if installed at 108* and the lash is correct. with the engine warm, lash should be .016 intake/.018 exhaust. aside from the vacuum issue, how does it run? throttle response should be crisp and power should be plenty to roast the tires at will. if it's not that way i'd say the tune is off considerably."
If nothing else, tells me I should be looking for more vacuum than I'm getting (which we already knew).
Re: Engine Vacuum? [Re: Damned67] #1462714
07/07/13 09:33 PM
07/07/13 09:33 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Keep at it!
Re: Engine Vacuum? [Re: Dodgem] #1462715
07/08/13 01:34 AM
07/08/13 01:34 AM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Thinking about it over my lunch break right now, I think I had a brain fart when setting up the carb after last years 'rebuild'.... I don't think I set the idle through both of the idle speed screws. That probably means that the primary side butterflys are open too far, exposing too much of the transfer slot, and leading to all sorts of problems....
Re: Engine Vacuum? [Re: Damned67] #1462716
07/08/13 10:49 AM
07/08/13 10:49 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea i like to have the throttle cable off to start and count how many 1/2 turns it takes to close both butterflies the make them exactly even and always open and close the same after that and set all four mixture screws the same too! especially on a Dommy.
