68 coronet 2 speed to 3 speed wiper conversion #146256
11/05/08 10:02 PM
11/05/08 10:02 PM
ne ohio
garymendy Offline OP
ne ohio
exactly what parts do i need to make this conversion..
can you give me a clear list so i know i am getting what i need?
thanks
email me if you can at garymendy@yahoo.com
Re: 68 coronet 2 speed to 3 speed wiper conversion [Re: garymendy] #146257
11/06/08 07:41 AM
11/06/08 07:41 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I put an airgrabber on a 69 GTX way back in the 80s. I changed to a 3 speed wiper motor and believe it or not the wipers still worked with the 2 speed switch. Later on when the dash needed to come mout for something else I replaced the switch. The wiring is the same. All you need is the motor, wired correctly to the bulkhead and switch. The dash harness is the same. I never changed anything on the wiper transmission either
Re: 68 coronet 2 speed to 3 speed wiper conversion [Re: Silverbullet2] #146258
11/06/08 08:01 AM
11/06/08 08:01 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
When I converted a while back, in addition to the switch and motor, there was a small plastic "cam" that went in the wiper linkage where the motor connects.
