DEF Diesel additive? #1462516
07/03/13 08:17 PM
07/03/13 08:17 PM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
I know its not a fuel additive and is used to keep the cat convertor clean but is it used only in large 18 wheeler type trucks or are there some late model cars and trucks that have a DEF tank?
Re: DEF Diesel additive? [Re: 69DartGT] #1462517
07/03/13 08:22 PM
07/03/13 08:22 PM
Pennsylvania
moparmaniac07 Offline
Pennsylvania
All new diesel pickups have it and a few cars do as well. I don't know which cars, but a few diesel cars do require DEF.
Re: DEF Diesel additive? [Re: moparmaniac07] #1462518
07/03/13 08:37 PM
07/03/13 08:37 PM
IN
ahy Offline
ahy  Offline
IN
Mercedes diesels use it. Maybe VW also. It is basically a solution of urea (fertilizer) and water.
Re: DEF Diesel additive? [Re: ahy] #1462519
07/03/13 09:06 PM
07/03/13 09:06 PM
UP
finn Offline
finn  Offline
UP
It's actually an 11% ammonia and distilled water mix, if I recall.
Problem is commercial (neat) ammonia sometimes isn't pure enough to use without building crystal deposits on the injector and substrate.
We used to mix our own in the lab. Cost $0.11/gallon to make.
Re: DEF Diesel additive? [Re: finn] #1462520
07/03/13 10:55 PM
07/03/13 10:55 PM
Kirkland, Washington
Pacnorthcuda Offline
Kinda sorta. Diesel Exhaust Fluid is really 1/3 urea (a nitrogen compound that TURNS to ammonia when heated) and 2/3 distilled/deionized water. When injected into the exhaust stream (think "after treatment") into a catalytic converter-type burner it very effectively consumes harmful oxides of nitrogen from the exhaust.
The beauty of this system, while cumbersome, is that it's an AFTERTREATMENT approach. Why do I stress this? Simple--the engine doesn't know it's there. Period.
What does that mean? Simple--the engine can be tuned for max mpg and power without regard to oxides of nitrogen.
That's a beautiful thing.
Re: DEF Diesel additive? [Re: Pacnorthcuda] #1462521
07/04/13 10:48 AM
07/04/13 10:48 AM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
Thanks, my son in law just dropped two 5 gal cans off while delivering a new Kenworth, trying to see who I can give this stuff to.
Re: DEF Diesel additive? [Re: 69DartGT] #1462522
07/04/13 01:03 PM
07/04/13 01:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
$2.69/gallon more you have to add to your diesel truck, I will never buy a new truck due to that and the less fuel mileage you get with the new ones. If I can keep my Cummins trucks running that is...
JB Rhinehart, Realist
A-Body's RULE!
Re: DEF Diesel additive? [Re: Rhinodart] #1462523
07/04/13 05:14 PM
07/04/13 05:14 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
The DD15 Detroits we run at work in the Freightliner Cascadias get 7-10mpg depending on how heavy you are hauling.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
