Voltage limiter? #1462190
07/03/13 12:51 PM
07/03/13 12:51 PM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Need to buy a new instrument voltage limiter should I try and buy an NOS or a new reproduction part? It's for a 69 Superbee. Thanks,
Re: Voltage limiter? [Re: superbeedave] #1462191
07/03/13 01:55 PM
07/03/13 01:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I believe someone is making an electronic one.Id just buy one off the shelf.Ive never had one go bad in over 40 years.Typically they dont go bad.Rocky
Chrysler Firepower
Re: Voltage limiter? [Re: therocks] #1462192
07/03/13 02:35 PM
07/03/13 02:35 PM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
I'd go with an RTE Limiter . Has worked well for me for years.
Dan
Re: Voltage limiter? [Re: Dans 68] #1462193
07/03/13 07:06 PM
07/03/13 07:06 PM
Cincinnati, Ohio
Cincinnati, Ohio
Dan
I don't see where it say's it is also for the 69 Superbee with the rallye gauges?
Re: Voltage limiter? [Re: superbeedave] #1462194
07/03/13 08:17 PM
07/03/13 08:17 PM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
The '69 Super Bee and the '69 Charger share the same Rallye guages; the limiter list you read from does not show every car model.
It is a nice piece of equipment.
Dan
Re: Voltage limiter? [Re: Dans 68] #1462195
07/03/13 08:44 PM
07/03/13 08:44 PM
Cincinnati, Ohio
Cincinnati, Ohio
The IVR4 looks like the one I need. But before I dish out $60.00 I just want to make sure this is what's causing my problem so I'm going to throw this at you. Every once in a while I will be cruising at 65 mph and I will notice my fuel gage and temp. gauge will start to rise but not peg then will come back down to normal. That sounds like a voltage limiter correct?
Re: Voltage limiter? [Re: superbeedave] #1462196
07/03/13 09:58 PM
07/03/13 09:58 PM
dogdays Offline
dogdays  Offline
Yes.
R.
Re: Voltage limiter? [Re: dogdays] #1462197
07/03/13 10:04 PM
07/03/13 10:04 PM
Cincinnati, Ohio
Cincinnati, Ohio
Why thank you! Thank you very much!!
