Orange box surge #1462026
07/02/13 10:53 PM
07/02/13 10:53 PM
Stouffville Ontario
7434 mopars Offline OP
Stouffville Ontario
My 70 Challenger equipped with an orange box has a surge
When removing the unit I noticed the screws where not tight
I replaced the unit with a original Chrysler unit off another car,
seems better after driving 15 minutes but noticed the idle has come up, and the response is a little slughish.
Will I need to adjust the timing ?
Re: Orange box surge [Re: 7434 mopars] #1462027
07/02/13 11:25 PM
07/02/13 11:25 PM
When reinstalling the ECU yes you'd want the 2 bolts/nuts to be tight. I'm wondering if you have a lean surge. OE AVS? If so you might block both piston/rod assy's up & take it back out for a spin & see how it acts on the power circuit. that'd be easy to do & would not cost anything. Holler how it goes.
Re: Orange box surge [Re: 7434 mopars] #1462028
07/03/13 06:47 AM
07/03/13 06:47 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Im sure you have heard this before and Im only repeating it as suggestion to help you out.
Ditch the Orange Box! You will never get the full potential out of your car until you do.
There are other alternatives out there MSD, Mallory and a few of the folks on here have there own alternatives to the stock set up that take minimal to no wiring changes that you could consider.
Good Luck.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Orange box surge [Re: BB65Barracuda] #1462029
07/03/13 08:08 AM
07/03/13 08:08 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Good Luck.
Never had an issue w/ any MP Orange box ever. I also have not noticed a difference in performace when switching over to MSD. You must sand the paint off the back and ground it well. Keep it away (like any other ECM) from heat and moister and you will be fine. If your car is surging I suggest you look at your carb. In general the ECM boxes either work or don't.
Coming soon!!!!
Re: Orange box surge [Re: Mr.Yuck] #1462030
07/03/13 12:46 PM
07/03/13 12:46 PM
MICHIGAN
MICHIGAN
I'm sure their are older orange boxes out there that preform as they should.
But that was before the manufacturing sector moved all of the electronic work out of the country in the early 80's.
That being said I just figured he had a newer box.
Im curious, you saw you don't see a difference between using an Orange box and an MSD Ignition? How about the retard in the timing around 4000RPM?
Re: Orange box surge [Re: BB65Barracuda] #1462031
07/03/13 04:00 PM
07/03/13 04:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had several since the 90's. timing retard? no idea but I ran the best et w/ this car using a New MP orange box (2010).
Re: Orange box surge [Re: Mr.Yuck] #1462032
07/03/13 05:10 PM
07/03/13 05:10 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I've also heard of orange box issues but never had an issue with the several I have used (using three right now). As suggested, sand the mounting area and use a couple star washers and secure it tightly. If you still have a problem, I am with others; probably not the box but rather fuel or timing.
Facts are stubborn things.
Re: Orange box surge [Re: larrymopar360] #1462033
07/03/13 10:01 PM
07/03/13 10:01 PM
dogdays Offline
dogdays  Offline
Not caused by the orange box.
R.
Re: Orange box surge [Re: dogdays] #1462034
07/03/13 10:44 PM
07/03/13 10:44 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
The orange case is the ground source for the electronics inside. You must make sure the orange box itself is grounded to the firewall properly or you'll have weird problems. You have to expose metal on the box as well as the firewall and make sure the two bare metal surfaces touch when bolted down. You can add a ground wire from one of the 4 screws if necessary.
Re: Orange box surge [Re: BB65Barracuda] #1462035
07/04/13 01:12 PM
07/04/13 01:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have had the same as Mr Yuck as my orange boxes have worked fine. In fact I still have an orange box on my 63 right now running 10's. But I bought mine around 2000 as I do hear alot of guys say the newer orange boxes are junk and will pull timing at higher rpms. All I can say is the orange box I bought in 2000 works great for me. And when we took the orange box off my boys Dart and put MSD on it the car ran no better or faster as it ran the same. Ron
