340 replaced cam/ oil to heads *DELETED* #1461850
07/02/13 02:07 PM
07/02/13 02:07 PM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
Post deleted by RTshaker
Re: 340 replaced cam/ oil to heads [Re: RTshaker] #1461851
07/02/13 04:16 PM
07/02/13 04:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
should that say NO lifters in their bores ?
If so no you won't get oil to the heads unless your lifter bores are bushed, or the main galley is tubed and oil blocked to the other side ... AND the cam is lined up to send oil to one side or the other .
