Re: 727 - Front piston & accumulator question
[Re: 6o4o]
#146156
11/06/08 12:00 PM
11/06/08 12:00 PM
Posts: 9,835 MI, usa
dvw
MI, usa
I always use both. 727 are notorious for overlap between the 2nd gear band releasing and the 3rd gear clutch applying. I've never hard a 2-3 flare or slip issue when using both springs. Also use the max number of springs that fit your high clutch piston,preferably 15. The stock steel rings are fine. Any local trans supplier will carry a metal ring kit. About $12 in our area. I have plenty if you can't get them easily in your country. Doug
[Re: dvw]
#146157
11/06/08 12:25 PM
11/06/08 12:25 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Are you talking about the piston in the front drum or the piston/servo that applies the 2nd gear band??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
