426 Hemi Dampner Help!! #146142
11/05/08 05:27 PM
11/05/08 05:27 PM
New York
R/T1968R/T Offline OP
New York
I was taking this 426 appart to rebuild it for a friend. The engine was laying for years and I really question the ability of the person who built it back then. When I removed the crank bolt I noticed the dampner was not flush with the end of the crankshaft. Is this normal on a 426? I know on RB motors that the dampner is flush. There is a 3/4" gap, as seen in the picture. Does this look right?
Re: 426 Hemi Dampner Help!! [Re: R/T1968R/T] #146143
11/05/08 06:56 PM
11/05/08 06:56 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Looks fine.Hemi takes a longer bolt.
Re: 426 Hemi Dampner Help!! [Re: R/T1968R/T] #146144
11/05/08 10:58 PM
11/05/08 10:58 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Just think where the back of the damper would be in relation to the timing chain cover if the front was flush with the bolt.
Sheldon
Re: 426 Hemi Dampner Help!! [Re: R/T1968R/T] #146145
11/06/08 12:06 AM
11/06/08 12:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
AS long as the balancer rearmost part of center is tight against the lower crank timing sproket, it is probably good.
