Upper Control Arm #1461408
07/01/13 08:50 PM
07/01/13 08:50 PM
san francisco
dawgfather Offline OP
san francisco
i took my K member apart and I think that the Ball joint for the upper control arm can be taken out and replaced. am I right or do I replace the whole upper control arm.. thanks
Re: Upper Control Arm [Re: dawgfather] #1461409
07/01/13 08:56 PM
07/01/13 08:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They unthread.Its easier if it bolted to the car.A special socket is needed to remove them.Year and make would help.Rocky
Chrysler Firepower
Re: Upper Control Arm [Re: therocks] #1461410
07/01/13 11:26 PM
07/01/13 11:26 PM
What Rock said, with everything undone unscrew the upper ball joint while the UCA is still installed in the frame, same thing when you install the new ball joint, do it with the UCA installed in the frame with the cam bolts/nuts. Need the special socket & a breaker bar. Might be able to get by with large pliers but for a first time deal you'd be ahead to get the socket
Re: Upper Control Arm [Re: RapidRobert] #1461411
07/02/13 10:35 AM
07/02/13 10:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Lots of penetrating spray also.That and when installing the new BJ make sure it goes in straight and tightens.I use a good impact to break mine loose.If you arent sure about it any good machine shop can do them.Its usually about 15 to 20 bucks a side.Rocky
Chrysler Firepower
Re: Upper Control Arm [Re: therocks] #1461412
07/02/13 10:42 AM
07/02/13 10:42 AM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
I did mine off the car and had a heck of a time. I used the special socket and an air impact driver to get them off. Then do like he says above.
Re: Upper Control Arm [Re: patosmith] #1461413
07/02/13 07:53 PM
07/02/13 07:53 PM
san francisco
san francisco
thanks guys..!! I almost took it to the shop and put it through a hydraulic press to press it out.. I will take a picture of it later to show you guys that I understand what you guys are saying... it came out of a 70 charger..
Re: Upper Control Arm [Re: dawgfather] #1461414
07/02/13 08:14 PM
07/02/13 08:14 PM
MN
E
ebodykid Offline
ebodykid  Offline
E
MN
I tried everything to get mine off my car with no luck.. had the socket, put tons of heat on it, and had a BF breaker bar.. but after a number of attempts, i was fearful of the socket jumping off and taking out my front fender... so i ended up replacing the UCA's... a cheating, more expensive way to do it, but i figured it was better that changing the shape of my front fenders...
Re: Upper Control Arm [Re: ebodykid] #1461415
07/02/13 08:23 PM
07/02/13 08:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Those things are torqued to 150 pounds. Not that much really. The threads are fat and flat - unlike anything I've ever seen before. From what I understand, the first time they're installed they more or less "self tap". Taking them apart you're primarily fighting rust. Impact guns don't quite cut it n my opinion - you really need a breaker bar and a 6 foot piece of pipe as an extension doesn't hurt! You want steady pressure, no sudden tugs, which will help keep the socket seated on the BJ.
Re: Upper Control Arm [Re: Stanton] #1461416
07/02/13 09:51 PM
07/02/13 09:51 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
A good impact will take them out.Ive done a bunch in the last 40 years.they also cut threads when reinstalled.Rocky
Chrysler Firepower
Re: Upper Control Arm [Re: therocks] #1461417
07/02/13 11:29 PM
07/02/13 11:29 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
A little does wonders when they are really stuck..
I am truckless..
Re: Upper Control Arm [Re: 340SHORTY] #1461418
07/03/13 02:06 AM
07/03/13 02:06 AM
san francisco
san francisco
ok here is the picture as promised and I am pointing at the part that I think you guys are saying to put the wrench to and unscrew. let me know if I am pointing at the wrong place
Re: Upper Control Arm [Re: dawgfather] #1461419
07/03/13 08:34 AM
07/03/13 08:34 AM
MN
E
ebodykid Offline
ebodykid  Offline
E
MN
yup, you need a tool similar to this balljoint removal tool.. Unless you have a lot of time to spare, i'd order it from somewhere else... I had ordered it from PST, and it took a while to get to me..
Re: Upper Control Arm [Re: dawgfather] #1461420
07/03/13 08:38 AM
07/03/13 08:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You are correct.That is the upper ball joint.As said you need the special socket.Some stores have the tool to loan.You will need a breaker bar and probally a pipe to get it out.Might be cheaper and easier to have a shop do them.Especially if you dont have some quality tools.The socket sell for around 30 bucks.I suggest you buy a factory service manual also.They are well worth the cost.I have them for all the cars we have.Rocky
Chrysler Firepower
Re: Upper Control Arm [Re: therocks] #1461421
07/03/13 09:41 AM
07/03/13 09:41 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I had my UCA out of the car, ran a pipe through where the bushings were mounted (obviously pressed those out first) and held the pipe with a vise, and it sounds crazy but I used a 3' pipe wrench. Like all have said, NOT an easy job to break loose. Though one was considerably harder than the other to get out.
Best wishes breaking these loose.
Re: Upper Control Arm [Re: AAR#2] #1461422
07/03/13 10:33 AM
07/03/13 10:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Those dont look too bad.Some of the worst I did was my 66 Imperial and the kids Express truck.Rocky
Chrysler Firepower
Re: Upper Control Arm [Re: AAR#2] #1461423
07/03/13 10:54 AM
07/03/13 10:54 AM
Actually that sounds very doable/practical. My mistake once was I clamped one leg in a vise & torqued it in then with the UCA back in the car (& the BJ bolted to the spindle) I found that I had bent one leg enough that it would not fit into the frame & my vise is huge & supported alot of the length of the leg & I was not torquing hard as it screwed in pretty easy I thought. Moral of the story is to have both legs supported either in the vehicle or with a pipe of the proper ID to fit the holes as described above when installing or removing the UBJ
