Re: Carter Carb Question AVS
[Re: Fastfrankie]
#1461258
07/01/13 06:52 PM
07/01/13 06:52 PM
Posts: 1,281 WI
wannadrag
WI
I have a Carter AVS on my 390 AMC engine. When the car sits for a few days, it will not start - it will just crank all day. I then took off the breather and I manually give it the throttle by hand and look down through the carb I do not see any gas squirting. Its not getting gas...
I get a small cup of gas and pour it into the carb and it starts right up and stays running and I'm good to go.
The fuel pump is new, the line is clean, and there is a new filter. I see gas in filter too...so there is gas getting there. The carb is super clean and it was rebuilt a year ago.
Bizarre...could it be something like the needle/seat or float sticks and prevents gas from coming into the carb, but once the engine runs it shakes it loose, allowing gas into the bowl?
Not bizarre at all if you google it,it seems to be pretty common.I have a freshly rebuilt AVS and it does the same thing.Soemtimes after a couple hrs the carb will be dry.Some of the problem is the crap gas and some I think is heat soak for me.Did these carbs have any heat barrier between the carb and intake?
[Re: bigblock340power]
#1461263
07/02/13 12:43 PM
07/02/13 12:43 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I'm having a similar problem with my Thermoquad. If I keep the truck in service everyday no problems. But let it sit for a few days/week, and it will not start for a few minutes. Put a cup of gas down the carb, and starts right up. I'm thinking crap gas (Oxygenated to the max, plus additives). Perhaps a weak fuel pump has something to do with it too. I'm going to get a dual action mechanical fuel pump today. I think with the crappy gas now a days, and the old stock fuel pump (that's only a few months old) is just not up to snuff.
what's a dual action mechanical fuel pump?
[Re: ademon]
#1461264
07/02/13 01:44 PM
07/02/13 01:44 PM
Posts: 75,023 U.S.S.A.
JohnRR
U.S.S.A.
Pumps on both the in and out movement of the arm
