Harmonic Damper / Pulley Bolts Help #1461203
07/01/13 03:09 PM
07/01/13 03:09 PM
Boca Raton, Florida
daveh1971 Offline OP
Boca Raton, Florida
Hi Guys,
I need a new set (6) harmonic damper bolts the ones that attach the crank pulley. Does anyone know the size and length? I just bought the damper below but Summit doesn't have a listing and didn't know when I called. I'm sure they are no different than stock but would like good ones like ARP if possible. Or comparable something that you may suggest. Thanks
http://www.summitracing.com/parts/pfs-90012
Re: Harmonic Damper / Pulley Bolts Help [Re: daveh1971] #1461204
07/01/13 03:55 PM
07/01/13 03:55 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
they are either 5/16 or 1/4 course thread , leaning toward 5/16 , 1/2" long .
Re: Harmonic Damper / Pulley Bolts Help [Re: JohnRR] #1461205
07/01/13 03:58 PM
07/01/13 03:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
5/16 by about 3/4 coarse thread will work. Would find a Mac's and get grade 8's.
Re: Harmonic Damper / Pulley Bolts Help [Re: MoparforLife] #1461206
07/01/13 04:38 PM
07/01/13 04:38 PM
Boca Raton, Florida
Boca Raton, Florida
Thanks what do you think about using stainless? I wanted to use something that wouldn't rust.
Re: Harmonic Damper / Pulley Bolts Help [Re: daveh1971] #1461207
07/01/13 05:21 PM
07/01/13 05:21 PM
scratchnfotraction Offline
I have a couple dozen in the shed, cover the ride of 6$ and shoot me a mail addy.
I have a lots of engine bolts if you need others.
Re: Harmonic Damper / Pulley Bolts Help [Re: scratchnfotraction] #1461208
07/02/13 11:05 AM
07/02/13 11:05 AM
Boca Raton, Florida
Boca Raton, Florida
Lowes had exactly what I needed in grade 8. Thanks guys.
