Testing Electric Fuel Pump Before Install
#1460780
07/01/13 10:20 AM
07/01/13 10:20 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am currently installing an electric fuel pump and before I put fuel through it, I just want to make sure that the pump itself works. I am tired of buying brand new electrical parts then installing them to find out that they are bad out of the box. I wanted to test the pump just to see if it would spin before I mounted it up. So I quickly put the black wire on the negative side of the battery and then touched the red wire on the positive side of the battery and all I got was a spark at the positive battery terminal. I then decided that this may not be the best way to test it, so now I am asking how to test it properly before I mount it. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Testing Electric Fuel Pump Before Install
[Re: YO7_A66]
#1460781
07/01/13 10:35 AM
07/01/13 10:35 AM
RapidRobert
Electrically that is how it is hooked up, no mistake there with what you did with the connections.
[Re: bonefish]
#1460783
07/01/13 11:11 AM
07/01/13 11:11 AM
YO7_A66
Indiana
I need to install the electrical connectors, so I will try and retest it with better connections. Thanks
[Re: YO7_A66]
#1460784
07/01/13 10:25 PM
07/01/13 10:25 PM
YO7_A66
Indiana
I put connectors on the wires and tried again. No pump movement and the top of the motor started getting warm. Unless the Holley Red pump is quiet as a mouse, then this pump has issues. Do these pumps get tested at the factory with white pipe dope? What got me to worry about this pump is when I pulled it out of the box, there was white thread sealant in the ports. I wonder if this was re-packaged at Summit. Before I call Summit, are there any chances that this pump is good?
[Re: YO7_A66]
#1460785
07/01/13 11:14 PM
07/01/13 11:14 PM
RapidRobert
it's been used if it came with no NPT fittings & there's pipe dope on the female threads of the pump. You hooked it right electrically as the spark tells you there is complete circuit continuity. It's a bad pump
[Re: markz528]
#1460787
07/02/13 07:25 AM
07/02/13 07:25 AM
YO7_A66
Indiana
My plan was to just hear it spin (quick test before hooking it up)and stop, but it never spun. I will be calling Summit to get a replacement.
Thanks allot.
[Re: YO7_A66]
#1460788
07/02/13 09:30 AM
07/02/13 09:30 AM
YO7_A66
Indiana
I contacted Summit and they will exchange it with no problems. They did say that Holley sends these boxed and ready to ship, so if anyone re-packaged the pump, it was Holley. They have one being shipped out today and I just need to ship mine back for a full refund.
Thanks for your help everyone.
[Re: YO7_A66]
#1460789
07/05/13 05:10 PM
07/05/13 05:10 PM
YO7_A66
Indiana
I received my second pump from Summit and I touched the wires (very quickly) to the battery and it spun! Thanks guys
