Re: 540 stroker from Mancini
[Re: BeeSuper]
#1460752
07/01/13 11:55 AM
07/01/13 11:55 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I would think it's a good kit. get ARP main studs or better a Hughes crank girdle kit. http://chucker54.stores.yahoo.net/hufiallmobig.htmlMancini also has some cap and girdle packages with new caps. next step up in caps and girdle http://www.bcrproducts.com/Some like to do a half fill of hard block (just to the top of the frost plugs) for a little extra cylinder support. some notching at the bottom of cylinder bores will likely be needed and an external pickup up system. Just my and some ideas.
[Re: Abodyjohn88]
#1460756
07/01/13 05:36 PM
07/01/13 05:36 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
I would think you will be better off going with a 500 inch stroker kit instead of the 540 with the stock block,a 4'5 inch crank is huge for a stock block and you may have some clearancing and strength issues. The 500 inch deal will be a relatively easy combo to put together.
I'm with this, that's a long arm and a lot of torque for a stock block.
[Re: JohnRR]
#1460758
07/01/13 05:59 PM
07/01/13 05:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its a STREET engine... pressure will be low and revs will be also for the most part... yes that would be a good street engine.. still will make good torque with low pressure and low rpm.. the stock block will handle it IF it measures ok
[Re: fullmetaljacket]
#1460760
07/01/13 11:13 PM
07/01/13 11:13 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
If I'm correct, Best Machine does all the fine tuning on those kits and short blocks. Good workmanship.
Shortblocks? I don't see them on Mancini's website.
[Re: BeeSuper]
#1460763
07/02/13 08:27 AM
07/02/13 08:27 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The 540 kit offers the advantage of lighter pistons, most likely, and for sure less rpm with a wider torque curve, more of it down low where a streeter likes it. I don't see any down side to the longer stroke in a stock block, provided you rev it where it wants to run-low rpm. You should be about as fast as you can be shifting below 6000 to 6200 rpm, and that would be with a VERY big cam. I like your choice.
[Re: BeeSuper]
#1460765
07/02/13 03:50 PM
07/02/13 03:50 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
From what you have posted, you can make MORE than enough power with a smaller efficient motor for what your doing. I am not a fan of putting a 4.500 crank in a stock block. I dont care HOW easy you think your going to be, thats a tough situation for a stock block. A 4.15-4.375 will do plenty. Your money though, just my
RIP Monte Smith
[Re: BeeSuper]
#1460767
07/02/13 04:00 PM
07/02/13 04:00 PM
MR_P_BODY
Thanks. I am gonna talk with Hughes Engines, real helpful guys and with Hensley,also seemed very helpful and knowledgable and get their opinion / perspective. I will be using my stock six pack set up and TTI headers. 4 speed, 4.10 dana (A-12 clone SuperBee) I'm told the intake will hold it back but my machinist warns that it only takes once to over rev that may hurt. Looking into a girdle and even partial hard block but still unsure. This car will be street driven modestly but I just know there may come a time when the excitement of an unexpected bout with a rice burner will have me giving it hell.
With a 4 speed and 4.10 gears you dont need that much torque... as some have said you might have a longer engine life if you go with the shorter stroke... unless its super heavy car... first gear might be close to useless
[Re: MR_P_BODY]
#1460768
07/02/13 04:33 PM
07/02/13 04:33 PM
Posts: 5,164 CT
GTX MATT
CT
Is anyone managing to run a 4.5 inch arm with a stock oil pickup? I've heard you can get away with it at 4.375, is it even within the realm of possibility?
[Re: FastmOp]
#1460769
07/03/13 12:33 AM
07/03/13 12:33 AM
Posts: 3,421 Toronto
mshred
Toronto
I have a 4.5 crank in my stock block. I run hi 5's low 6's depending on if I'm bracket racing or index racing. Built it 2010. I like the 541 combo. My crank is from 440 source
Any hard block or a girdle? What rpms do you turn?
[Re: mshred]
#1460770
07/03/13 01:10 AM
07/03/13 01:10 AM
gregsdart
With a Six Pack intake your motor may be all done at 5200 rpm? That more than offsets the longer stroke, and I can understand some not liking that long of an arm in a stock block, but before saying it is not the right way to go, I would really like to see a stress analysis done using all the right numbers between the possible choices. I am willing to bet that there is less stress on a 4.50 stroke 7.10 rod motor using those heads and the right rpm, than there is with a 4.15 stroke motor with a bit heavier piston, along with attending higher rpm before the motor runs out of cylinder head flow. I have run a 4.5 stroke stock block combo, and with iron heads flowing about 280 cfm. It liked a shift point of 5700 rpm, and that was with a hogged out tunnelram and twin 800cfm holleys. It made decent power for what I put in it, and other than some cap walk, wasn't a problem till the crank broke. For a bigger head, I would agree that it would be pushing it. A 440-1 or similar head with a matching intake system would be walking on thin ice. But I have a friend that races that package, running low nines in a 3000 lb car on a regular basis.
