Rear Bumper question for a 1974 Barracuda #1460675
07/01/13 01:16 AM
07/01/13 01:16 AM
NY
K
Killerinc Offline OP
K
NY
Hey, got a question that I know can be done but not sure about the safety of it.
I removed my bumper off my 74 Plymouth Barracuda and there is a steel plate behind it I guess for reinforcement. What I would like to do is to cut out just the section of the steel plate that fastens to the rear mounting brackets and discard the middle part to cut down on weight. Anyone have any thoughts on this?
Re: Rear Bumper question for a 1974 Barracuda [Re: Killerinc] #1460676
07/01/13 07:11 PM
07/01/13 07:11 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
There's no problem in removing the plate. If you need to off-set the bumper, just stack a couple of washers behind the bumper. Obviously the bumper is not going to be as strong w/o the reinforcement plate.
Re: Rear Bumper question for a 1974 Barracuda [Re: Killerinc] #1460677
07/01/13 08:24 PM
07/01/13 08:24 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
I also have a 74 barracuda. I removed the bumper and plate. I thought about the safety thing but I could not stand the stupid bumper guards. So I installed a 72 bumper with 72 guards and brackets. To answer your question though, if you remove the center section allowing you to keep the original bumper brackets etc... you really loose all the safety of that system since it bolts into the rear frame rail ends and creates a boxed in structure. One thing to keep in mind though is that the 70 through 72 cars are just as unsafe so your not creating something that hasn't been done.
Re: Rear Bumper question for a 1974 Barracuda [Re: cudabitten] #1460678
07/03/13 12:22 AM
07/03/13 12:22 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
That steel plate was simply to strengthen the bumper to meet the 5mph crash requirements that were imposed by the Feds back then.
Mine on my 74 challenger are long gone in favor of 70-72 bumpers and brackets.
Re: Rear Bumper question for a 1974 Barracuda [Re: G_bob] #1460679
07/03/13 12:31 AM
07/03/13 12:31 AM
North Texas
3
360cuda Offline
360cuda  Offline
North Texas
I removed the plate from mine, front and rear. Then I had a bumper shop weld the bumper guard holes, and the jack slots closed. I removed the rubber spacers that extend the bumpers. I bought a full set of 1970 bumper brackets and bolted them on after re-chroming. They look great. It gives the car a very clean appearance. I have always loved the 73-74 E-body's, but hate the battering ram bumpers.
Re: Rear Bumper question for a 1974 Barracuda [Re: 360cuda] #1460680
07/03/13 05:06 PM
07/03/13 05:06 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
Amen to what you and G_Bob said.. I recessed the bumpers on my 73 Challenger, so that now it looks like a 72. Couldn't wait to shed those huge chrome and rubber bumper guards. Best mod I made to the car.
Re: Rear Bumper question for a 1974 Barracuda [Re: 360cuda] #1460681
08/10/13 03:09 AM
08/10/13 03:09 AM
NY
K
K
NY
Thanks for all the advice everyone and i will try it.
After i shaved and welded the bumper bolts and closed up all the holes, now no re-chromer wants to touch it. Any suggestions.
Also upon removal i noticed one of my rear bumper brackets sticks out too far or one was bent in, should i just get new ones off a 72 or bend it back. Also does anyone know the specs oh the distances away from the body
