the top right as you you look at it?
It is the 5A fuse.
And when should it light up when testing?
running or just keys on or off, no test light on either side of fuse.
I am tracking down a couple of things.
oil pressure and temp gauges work, so volt reg. should be good, but fuel gauge is always on E, no matter what I do, remove sending wire from stud, place on bullet proof ground at tank, etc. stays on E.
Also, is there a way to test horn relay/relay slots. I can bench test my horn, but in car nothing.
I was thinking if I had the blades of the horn relay most of the way in, I could probe each with a test light and test horn button on steering wheel.
Thank you for any information.
