Tranny pan gasket torque? #1460050
06/29/13 08:37 PM
06/29/13 08:37 PM
Kirkland, Washington
Pacnorthcuda Offline OP
Working on the wife's 2006 liberty. Auto tranny. The factory spec for the pan bolts is 14.5lbs or 174 inch pounds. BUT the factory didn't use a gasket, just RTV/sealer of some sort. Once the sealer is squeezed out there is really no more "squish" and torque values rise very quickly with bolt rotation.
I'm using an ATP fiber gasket (I like their gaskets), but think that much less torque is appropriate. I'm thinking more like 75-100 inch pounds....
Thoughts? Advice?
Re: Tranny pan gasket torque? [Re: Pacnorthcuda] #1460051
06/29/13 08:39 PM
06/29/13 08:39 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
PACman .. just "snug" with a 1/4 ratchet ....
Re: Tranny pan gasket torque? [Re: Pacnorthcuda] #1460052
06/30/13 12:35 AM
06/30/13 12:35 AM
Thoughts?
I'd think a gasket would take more torque than RTV rather than less but I think I'd stick with the OE specs. I would for sure go side to side several times & come up on the torque # in several steps like any other torqued part
