Speedometer Cable #1459920
06/29/13 11:18 AM
06/29/13 11:18 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi. I need a new speedometer cable for my GTX. The one from AZ didn't last . Back in the day, I remember you could go down to the dealer and buy one for mid seventies cars cheap, but they were the wrong color. Does anyone know if those are still available and the PN? Thanks
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Speedometer Cable [Re: Hrtbkr] #1459921
06/29/13 11:58 AM
06/29/13 11:58 AM
Central TX
roe Offline
roe  Offline
Central TX
Maybe you got a bad one. The one I have is from the zone. Actually it's 3 that I made into one because they didn't have an exact fit. But I did disassemble and use a high heat synthetic wheel bearing grease to lube it. There was surprising VERY little lube on the thing out of the package.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
