Maybe you got a bad one. The one I have is from the zone. Actually it's 3 that I made into one because they didn't have an exact fit. But I did disassemble and use a high heat synthetic wheel bearing grease to lube it. There was surprising VERY little lube on the thing out of the package.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
