100 amp alternator mounting on 440 w/o a.c. #1459650
06/28/13 06:42 PM
06/28/13 06:42 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
I have a 77 D100 with a 440 that came with the 100 amp alternator mounted on it. I had to tear the engine down to replace the heads, cam, etc... It's been apart long enough that I can't remember how the alternator was mounted. I know this may sound ridiculous to some of you guys, but I'm having a heck of a time trying to figure it out. I have researched on line and can't seem to find a set up like mine. My mother warned me that partying too hard in the 70's would catch up with me one day. Looks like it has! Any input would be greatly appreciated. Thanks.
Re: 100 amp alternator mounting on 440 w/o a.c. [Re: elmor353] #1459651
06/28/13 08:25 PM
06/28/13 08:25 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Sorry I'm no help ....but I do know what ya mean about the 70's!! lol
Anyway here's a bump for ya!
Re: 100 amp alternator mounting on 440 w/o a.c. [Re: Dcuda69] #1459652
06/28/13 11:39 PM
06/28/13 11:39 PM
IN
ahy Offline
ahy  Offline
IN
Here's a pic of a low deck with AC. Not exactly what you want but hope it helps.
That bracket is build like a bridge truss. There is an angled bracket going back from the front bracket to the head.
Re: 100 amp alternator mounting on 440 w/o a.c. [Re: ahy] #1459653
06/28/13 11:49 PM
06/28/13 11:49 PM
That alternator doesn't look like a Mopar alteranator, is it? If not, it may not be much help as he is wanting pictures of a OEM 100 amp Mopar alternator on a 440 non air conditioning vehicle
Re: 100 amp alternator mounting on 440 w/o a.c. [Re: Cab_Burge] #1459654
06/28/13 11:53 PM
06/28/13 11:53 PM
IN
ahy Offline
ahy  Offline
IN
That's the OE alternator on a '78 Cordoba core engine.
Re: 100 amp alternator mounting on 440 w/o a.c. [Re: ahy] #1459655
06/29/13 04:20 AM
06/29/13 04:20 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Still different than what I have. I'm wondering if what I have was cobbled together by the previous owner. Wouldn't surprise me, everything else on this thing has been butchered. Since when did a new set of shocks become a rebuilt suspension? Frustrating when you trust someone's word and later find they lied through their teeth. I managed to get it back together, but will look for the correct brackets to make it right. Thanks guys.
Re: 100 amp alternator mounting on 440 w/o a.c. [Re: elmor353] #1459656
06/29/13 06:30 AM
06/29/13 06:30 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I have all the correct brackets for those 100 amp alternators, on the big block engines.
PM me, if your interested.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 100 amp alternator mounting on 440 w/o a.c. [Re: elmor353] #1459657
06/29/13 02:35 PM
06/29/13 02:35 PM
AndyF Offline
AndyF  Offline
The service manual should have some pictures in it. The 100A setup is fairly common on the trucks so you might find something in a wrecking yard that is close. There is probably an idler pulley setup that replaces the AC unit. If you mount the idler up first and then the crank pulley you'll see where the alternator has to go. Once you know where it has to go you can sort out the brackets.
