Re: At what point is QUENCH not effective?
[Re: Jjs72D]
#1459362
06/28/13 09:08 AM
06/28/13 09:08 AM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You would lose some benefit, but a lot of it is not there due to being at .059 already, IMHO. If you can, fix it right with setting the proper quench. Study what happened to the same motor when compression dropped from the factory back in the early 70s. That is a big clue as to what will happen to your motor. It all depends on what you want. Do you want it to run the best and spend the money, or do a quick fix and live with a motor that is down on torque? The other thing to consider is what cam you have. If it is bigger than stock, then reducing compression will be a double whammy. The motor will suffer even more loss, because your true compression will take a bigger hit. A total run down on what you are working with would help you get better responses also. There may be other options here, but we need facts to work with.
[Re: Jjs72D]
#1459363
06/28/13 09:09 AM
06/28/13 09:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I cant answer your question(I dont have the smarts or the experience)but I would ask what fuel, timing, cam and where its installed at.. also how hot do you run the engine at and what plugs you run... yes your correct that .040 seems to be the best point for it.. a thicker gasket can cause it to detonate even more (just like the low compression engines can detonate)
[Re: Jerry]
#1459367
06/28/13 10:05 AM
06/28/13 10:05 AM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
I agree that the ideal quench clearance is about .035, dependent on piston rock. The detrimental area is clearances of about .040 to .100, which generally leaves areas of combustion that are too small to efficiently ignite the mixture. Above .100 will be more efficient because the area is large enough to allow the flame travel to burn the mixture within a short enough time span.
Be a Rebel- Break the Laws of Physics!
[Re: Jerry]
#1459368
06/28/13 10:06 AM
06/28/13 10:06 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
When you are spraying 400hp of Nitrous, quench is not effective, head gaskets aren't either.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1459369
06/28/13 11:05 AM
06/28/13 11:05 AM
Posts: 6,567 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Funny. Too bad it's true. Although I would think having quench couldn't hurt.
Kevin
[Re: Crizila]
#1459372
06/28/13 12:27 PM
06/28/13 12:27 PM
Posts: 22,697 Bitopia
jcc
Bitopia
Address the quench first. There is no magic #. Tighter is better. .035' - .040" is safer. Address the detonation with fuel, ignition timing, cam timing, water.
So my first assumption is the purpose of quench is to keep the mixture uniform in temp and maintain fuel/air mixture, and possibly cool relative hot spots in the chamber. And I freely admit we are not speaking F1/Nasacar here, but to move the amount of air that quench does, in 8 cyls, at 7K?, I bet it takes/absorbs a reasonable amount of horsepower to move all that air from a dead stop, really fast. But if it allows greater hp to be made, that offsets and exceeds the pumping losses, we then chase quench. Forgetting mechanical issues of quench, regarding rod stretch, growth, etc, it would seem there should be a magic quench goal for each engine combination. What that is, I have no clue.071
[Re: Jjs72D]
#1459375
06/28/13 01:27 PM
06/28/13 01:27 PM
Posts: 4,210 New York
polyspheric
New York
Everyone speaks, no one listens
Boffin Emeritus
[Re: polyspheric]
#1459376
06/28/13 01:35 PM
06/28/13 01:35 PM
jcc
Bitopia
So all? the benefit arises from the additional power obtained from the now lessened volume of quench area, and that the quench area no longer pre ignites from the shock wave, because its cooled by its close proximity to the piston and the head, and burns later, correct? Interesting.
[Re: jcc]
#1459377
06/28/13 01:36 PM
06/28/13 01:36 PM
Posts: 7,506 Az
Crizila
Az
The #1 purpose of quench is to try and eliminate a second flame front. Then do what you said, which also helps to eliminate a second flame front. Since everyone likes .040', that makes it the magic #. There is a reason why the most common head gasket thickness sold ( for wedge motors ) is .039" - and it's because most aftermarket and race engines are built with "0" deck height - or close to it. So now that you have the "magic" quench #, I hope your build is just as magic. With pistons .020 in the hole at TDC, a little magic could be in order.
Fastest 300
[Re: polyspheric]
#1459378
06/28/13 01:40 PM
06/28/13 01:40 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
Ive seen a few good examples of good effort being put into quench and what happens when its not. I have seen two 360s very similar other than one being a quench motor and one not. The quench motor was a 10:1 deal and the non quench was in the 9s. The quench motor was able to run a good amount more timing with little problems with knock. The other motor constantly fought with knock and would put some race gas in so he could run the timing where it needed to be on the track. The quench motor was also about .75 faster in the 1/4 in a slightly heavier car. This was like 15 years ago so the details are a little fuzzy, it did however burn "quench is good" into my head for life.
I often wonder about the stroker 4.0 in my jeep. I built it in a hurry and didn't put forth any effort into quench etc. I just followed a canned recipe for a budget stroker motor. Its mid 9s compresion and fights detonation with premium fuel in the warmer months. I often wonder how much power and efficiency I left on the table by not going the extra mile and putting some effort into quench. I was however in a time crunch as it was my daily driver and I blew the motor up(ingested water).
68 Barracuda Formula S 340
[Re: 383man]
#1459380
06/28/13 07:46 PM
06/28/13 07:46 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
My small chamber W8 468 CID nitrous combo had huge compression. We installed a dish piston with. Lost so much compression the engine was down on power. Then installed a.032 head gasket and power came back and the rings ran cooler.
My 421 with same heads and flat tops was also high on compression. It made great power over a broad range.
My Durango RT needed a rebuild. I cut a bunch off the block to develop quench as this thing detonated terrible. Raised compression at least a half a point. Well it spark knocks more now. So win some loose some.
Race engines like quench. Nitrous engines love it even more. In my experience. But, the Durango said I was full of crap.
So who knows. Two out of Three I will build quench in future builds.
