Re: Grandkids first hot rod
[Re: ]
#1459351
06/28/13 10:41 AM
06/28/13 10:41 AM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
[Re: pushbutton]
#1459354
06/28/13 02:57 PM
06/28/13 02:57 PM
Posts: 1,513 AZ
Mike P
AZ
Thanks for the comments guys. “……..are you going to upgrade to a gas engine? I'd think the starter would burn out fairly quickly at constant use?????......” I’d like to, mostly to give Cade some firsthand experience with engines and because I firmly believe if it’s got wheels it should burn dead dinosaurs. We had started out with a 55 year old 2 stroke engine but after getting it cleaned up we found out it needed some parts (that I’m still looking for). Cades going thru a growing spurt and may not fit in the car much longer so I made the decision to go electric for now just to get it going. As far as the motor lasting, we’ll have to see. I came across a site where people were building homemade golf carts using these old Ford starters and they seemed to have fairly good luck as long as they could keep them cool. I removed the tin cover over the brushes, drilled the end plate with vent holes and added a fan a shroud. So far it seems to be doing pretty good, it’s probably got over 3 hours on it and is still going strong ( I have a couple more sitting on the shelf just in case).
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: wannadrag]
#1459357
06/28/13 11:27 PM
06/28/13 11:27 PM
Posts: 10,614 Freeport IL USA
poorboy
Freeport IL USA
That's cool! I've been helping my grandson build a go kart. We started out with a riding mower, built a frame, and moved everything we could use from the mower to the frame. We got it running a month or so ago, but have been having drive belt issues. We finally got that under control and he was out beating paths around the yard. Around the 15th lap or so, he blew up the motor. Sorry, no video. I took the motor apart yesterday, melted down the rod and stuck it to the crank. Got everything apart and have most of the aluminum off the crank. I think we can get away with a rod, some rings, and a gasket set, but that will be a couple weeks away. We are funding challenged until after holiday at least. I have located another running motor, I have located parts to fix this motor, and I have a parts motor that either needs rebuilt, or I can hijack the parts for the current motor, but any way we go is about the same money. So much for a cheap go kart.
At least it looks like the mini hot rod you built will have a line of users if your grandson out grows it. Gene
[Re: poorboy]
#1459358
06/29/13 06:35 AM
06/29/13 06:35 AM
Posts: 1,513 AZ
Mike P
AZ
".....At least it looks like the mini hot rod you built will have a line of users if your grandson out grows it....." Yup, that's kind of been planned for. With the difference in sizes of the kids the pedal (switch) sits in a slot in the floor and can be moved for the different legnth in legs.
