are cheetah manual valve bodies woth the price? #145925
11/05/08 03:16 AM
11/05/08 03:16 AM
Anonymous OP
Anonymous OP
thinking about getting a standard pattern manual cheetah valve body and wanted some opinions on them
Re: are cheetah manual valve bodies woth the price? #145926
11/05/08 03:54 AM
11/05/08 03:54 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Never had a forward pattern,but I have used the reverse pattern one. I was happy with it.
Re: are cheetah manual valve bodies woth the price? [Re: slantzilla] #145927
11/05/08 08:06 AM
11/05/08 08:06 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Had the manual forward with LBA in two transmissions over the last couple years. I Like it.
Re: are cheetah manual valve bodies woth the price? [Re: bobby66] #145928
11/05/08 08:43 AM
11/05/08 08:43 AM
Anonymous OP
Anonymous OP
I just got one. its the manual/automatic and I love it. nice shifts. clean and crisp.
Re: are cheetah manual valve bodies woth the price? #145929
11/05/08 08:56 AM
11/05/08 08:56 AM
usa
mrmopardan Offline
mrmopardan  Offline
usa
I have a auto/manual also. Works great..
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: are cheetah manual valve bodies woth the price? [Re: mrmopardan] #145930
11/08/08 07:14 PM
11/08/08 07:14 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
So gentlemen, help me to understand the forward pattern (PRND21) automatic/manual valve body concept.
You can put the gearshift lever in the "D" position and the transmission will shift for you? Why buy/use it then (sounds like the functions of an automatic transmission)?
Or, you can shift it manually with the gearshift lever?
I thought that, with a manual valve body, whatever position you put the gearshift lever in was the gear you got (eg. position "1" = 1st gear, postion "2" = 2nd gear, and position "D" = 3rd gear)? Is there still a need for the kick-down linkage?
Please shed some light on the Black Magic Voodoo that is a transmission!
Re: are cheetah manual valve bodies woth the price? [Re: DartGTDan] #145931
11/08/08 07:42 PM
11/08/08 07:42 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
A true manual valve bodies mean that you must manually shift your automatic transmission. You have to shift each gear without exception. Once you have convertied to a manual valve body, the transmission will no longer shift automatically. Manual valve bodies are great because they usually allow for a longer transmission life (stronger). And you don't need linkage anymore which is nice. BTW, Mine is a forward valve body and I like it.
Re: are cheetah manual valve bodies woth the price? [Re: DartGTDan] #145932
11/08/08 07:42 PM
11/08/08 07:42 PM
Burma Shave
plymouthfan Offline
plymouthfan  Offline
Burma Shave
I don't own one of these valve bodies (yet), but this is how I understand it, please correct me if I'm wrong....
You are correct in that the auto/manual is nothing more than a regular automatic valve body. The idea of the auto/manual valve body is simply that it already has a shift kit installed. So, if you have it in D, the automatic shifts will be much crisper, or you can shift through them manually... your choice.
I assumed you WILL need a kickdown because you do not shift it manually back to first until AFTER the car comes to a full stop.
One red car, one yellow car.
Re: are cheetah manual valve bodies woth the price? [Re: plymouthfan] #145933
11/08/08 08:07 PM
11/08/08 08:07 PM
with a shift kit added the shifts are crisper & you stay in D & it just shifts harder/better & a kickdown linkage is still needed & you should not manually shift it between gears. full manual valve body you DO shift into/out each gear manually just like a stick shift & no kickdown linkage needed. I believe a reverse pattern valve body with the attending reverse pattern on the shifter is to keep a person from(with a manual valve body) from going past the D & into N or R when manually shifting from 1 to 2 then to D as you don't want to overshoot the D during the race & with the reverse pattern you are heading toward the D & there's nothing to overshoot.
Re: are cheetah manual valve bodies woth the price? [Re: RapidRobert] #145934
11/08/08 09:27 PM
11/08/08 09:27 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
I have had one in my last two cars and I also love it great piece for the small price tag
www.sikosracing.net Heads up Drag racing
Re: are cheetah manual valve bodies woth the price? [Re: moparmattkos] #145935
11/08/08 11:01 PM
11/08/08 11:01 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Once you run a manual VB you will never go back.
Keep old mopars alive.
Re: are cheetah manual valve bodies woth the price? [Re: 2boltmain] #145936
11/09/08 10:27 AM
11/09/08 10:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You have to shift a true full manual valve body. I prefer the reverse pattern as I like to race sometimes and I prefer to pull the shifter back towards me as I shift. Ron
Re: are cheetah manual valve bodies woth the price? [Re: 383man] #145937
11/10/08 12:04 AM
11/10/08 12:04 AM
Anonymous OP
Anonymous OP
i run the manula/automatic cheetah. works great with the slap stick shifter.
3 is full auto. seconf is 1st and 2nd. shifts hit hard and crisp. one of the best things ive done to it
Re: are cheetah manual valve bodies woth the price? #145938
11/10/08 08:23 AM
11/10/08 08:23 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i run the full man. forward w/a hurst qutr.stick, pretty hard to mess up a shift.
