700r4 in 75 w100 with 360 gas #1458960
06/27/13 01:16 PM
06/27/13 01:16 PM
arizona
stockerbill Offline OP
arizona
Don't bash me too hard Plz? Any one ever done this and what transfer case should I run? I never tow or beat my old girl, I just want a o/d with lock up converter and no computer. OK give it to me
Re: 700r4 in 75 w100 with 360 gas [Re: stockerbill] #1458961
06/27/13 01:58 PM
06/27/13 01:58 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That's an interesting swap, but you'd have to be running some steep gears for it to be worthwhile I think. Every old ram I had with standard gearing(321-355) was hurting on the highway with overdrive. That was with 33's though mostly.
Re: 700r4 in 75 w100 with 360 gas [Re: stockerbill] #1458962
06/27/13 02:40 PM
06/27/13 02:40 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I have never done it but would use a 700r4 and a 208 or 241, buy a trans and case together is how I would do it. Make sure you get a pass side drop case. Try pirate 4x4 website for better advice, should be an easy swap.
Re: 700r4 in 75 w100 with 360 gas [Re: buildanother] #1458963
06/27/13 02:42 PM
06/27/13 02:42 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
700r4 is GM IIRC. Why not just go with a 90/93 4x4 version of the 518? Much easier to install..
I am truckless..
Re: 700r4 in 75 w100 with 360 gas [Re: 340SHORTY] #1458964
06/27/13 03:53 PM
06/27/13 03:53 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The ultra bell needed will cost you close to $500 plus you have to run the GM version Transfercase. You can get a 518 for under $500 and it will bolt to your t-case
You truck your money
Re: 700r4 in 75 w100 with 360 gas [Re: 76dodgeboy] #1458965
06/27/13 04:18 PM
06/27/13 04:18 PM
arizona
arizona
Thx Much! , I have a adapt plate left from 1 of my old drag cars and the mope trans don't have o/d and lock up converter with no wires like you can do with a 700r4! I will never beat on it hard so it will live. I am hard core Mopar,(been drag racin these cars from 1968 until 2 years ago) however they don't have what I need for my old power wagon so here goes!
Re: 700r4 in 75 w100 with 360 gas [Re: stockerbill] #1458966
06/27/13 04:21 PM
06/27/13 04:21 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The early 518s are from my understanding just a couple wires and a switch. Youll still need to source a gm Transfercase and probably Fab a crossmember or mod currect. I plan on a 518 behind the 400 in my wifes 70s Powerwagon. She wont wheel it like I plan to mine.
Good luck
Re: 700r4 in 75 w100 with 360 gas [Re: buildanother] #1458967
06/27/13 04:22 PM
06/27/13 04:22 PM
arizona
arizona
fact 391 gear and stock 15 inch tires, it has the wind knocked out of her on the freeway
Re: 700r4 in 75 w100 with 360 gas [Re: stockerbill] #1458968
06/27/13 04:27 PM
06/27/13 04:27 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
31s came stock. 33s will fit if 9.50 or possibly 10.50
Re: 700r4 in 75 w100 with 360 gas [Re: 76dodgeboy] #1458969
06/27/13 05:14 PM
06/27/13 05:14 PM
arizona
arizona
I never measured them? it has 235/75/r15's and at 65 mph she is at 3grand(rpm) and isn't happy at all!
Re: 700r4 in 75 w100 with 360 gas [Re: stockerbill] #1458970
06/27/13 06:03 PM
06/27/13 06:03 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
29" give or take with brand
Re: 700r4 in 75 w100 with 360 gas [Re: 76dodgeboy] #1458971
06/27/13 06:08 PM
06/27/13 06:08 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
31s will put you around 2755rpms
33s at 2588rpms
Re: 700r4 in 75 w100 with 360 gas [Re: 76dodgeboy] #1458972
06/27/13 06:34 PM
06/27/13 06:34 PM
arizona
arizona
Again, Thank You!! That is Great info!
Re: 700r4 in 75 w100 with 360 gas [Re: stockerbill] #1458973
06/27/13 08:13 PM
06/27/13 08:13 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Ramchargercentral has a calculator for such things
Re: 700r4 in 75 w100 with 360 gas [Re: 76dodgeboy] #1458974
06/27/13 08:47 PM
06/27/13 08:47 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Good luck
yep if you can find an early 518 they had 3 wires 1 hot and 2 grounds.
and if my memory serves me correctly they even had a 518 that had no lock up, so any 727 converter would work but they would be harder to find
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 700r4 in 75 w100 with 360 gas [Re: dusturbd340W5] #1458975
06/27/13 10:21 PM
06/27/13 10:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
and I remember reading a post where someone added a vacum switch that made the trans work normally instead of needing to manually turn the switches on and off..
I am truckless..
Re: 700r4 in 75 w100 with 360 gas [Re: stockerbill] #1458976
06/27/13 11:36 PM
06/27/13 11:36 PM
houston, tx
d100clubcab Offline
d100clubcab  Offline
houston, tx
I'm sort of in your shoes.
I have 31 inch tires and 3.23 gears
she just purrrrs at 65 tho
even 70 at times
75+ is when i hear her straining
i do 34 straight shot freeway miles each way every day
but i want 4.10 gears to do better from stop light to stop light
and add a518 with that overdrive to still keep her purring at 65 on the freeway
i have to find the tranny first tho
