Re: Slap Stick - Worth it?
[Re: cudabitten]
#145838
11/07/08 12:34 AM
11/07/08 12:34 AM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
Hi I asked this question before but did not get any definite answer. My barracuda has a 904 auto console on the floor but does not say "slapstik". Whats the difference? Can I make it a slapstik?
What year Barracuda? All E-body console automatics are Slap Stik, whether 904 or 727.
A-bodies never came with the Slap-Stik.
[Re: 318 Stroker]
#145840
11/07/08 08:40 AM
11/07/08 08:40 AM
Posts: 958 eastern, pa.
cudabitten
eastern, pa.
Are you sure? mine is a 74.
[Re: cudabitten]
#145841
11/07/08 09:27 AM
11/07/08 09:27 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
It should be a slapstick , if it's not it will be easy to make it one .
As far as it being worth it , it is if you feel the need to manaully shift it alot , like drag racing , just don't down shift to 1st while moving over 5mph , if you don't it it hardly worth the effort .
[Re: cudabitten]
#145843
11/07/08 10:59 AM
11/07/08 10:59 AM
318 Stroker
St. Louis, Mo
Yep, I'm sure. Maybe it doesn't say Slap Stik, but if it's the original shifter for the car, it is one. Now if someone monkeyed with it over the years, that could be a different story.
[Re: 318 Stroker]
#145844
11/07/08 12:36 PM
11/07/08 12:36 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Mine is a '74 and it also does not SAY slap stik But, if you put it into 1st and push forward, does it lock into second until you let off pressure? Then, when you push forward does it lock into drive? If you answered "yes" then its a slap stik
