Where can I get a new yoke ? I'm hoping this will solve my vibration problem since the only 2 things that are not new is the trans yoke and the axles. I had a new drive shaft made and balanced 2 times. I had the motor balanced 2 times. Flywheel, clutch, and pressure plate included. 1st motor balance job was way off.
Motor is good now and trans shifts good. I think the end play for the yoke is supposed to be .008" but I seem to have more.
The vibration starts around 60 mph and buzzes the mirror the faster I go. Any suggestions ? After 12 years of working on this thing I'm about ready to sell. Between the vibration problems and the carb it's not enjoyable at all !
