67 Barracuda windshield question #1458252
06/25/13 07:01 PM
06/25/13 07:01 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Does a 67 Barracuda fastback have stainless trim around the windshield and back glass. Thanks
Re: 67 Barracuda windshield question [Re: bobs69] #1458253
06/25/13 07:04 PM
06/25/13 07:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Not really. 67 is only year only for front and rear windshield trim for A-bodies. The have plastic chrome plated stripes. I think there may be corners that are stainless. They are a PITA.
Re: 67 Barracuda windshield question [Re: autoxcuda] #1458254
06/25/13 07:42 PM
06/25/13 07:42 PM
If you can round up the parts, the best thing to do is swap for the later stainless trim. You will have to also use the later rubber gaskets and clips, and drill holes for the clips.
Switching was easier 25 years ago when I converted mine because you could still find what you needed in the local junkyard.
Front is easier, because the stainless trim and gasket from any non-Duster type A body hardtop (and maybe sedans, too, I don't know) 1968 through 1976 will fit. For the rear, you're limited to 68-9 fastback Barracuda.
