Anyone Racing a Leaf spring rear with the Alterkation #1457979
06/25/13 12:33 PM
06/25/13 12:33 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I'm curious as to how anyone is running this combo...you need a lot of front end travel for this to work and it looks like your limited with the Alterkation.....any thoughts
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: 10secGTX] #1457980
06/25/13 12:55 PM
06/25/13 12:55 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I run a Magnumforce front end with leafs...So far, a 1.50 60ft...Still tuning.
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: 10secGTX] #1457981
06/25/13 02:23 PM
06/25/13 02:23 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Al's lil tire car runs an AK front / leaf rear...
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: J_BODY] #1457982
06/25/13 02:34 PM
06/25/13 02:34 PM
Renton Washington
Triple Threat Offline
Renton Washington
Ladder bar
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: Triple Threat] #1457983
06/25/13 02:54 PM
06/25/13 02:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I stand corrected!
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: 10secGTX] #1457984
06/25/13 04:11 PM
06/25/13 04:11 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
I have 2 customers with that combo and it does not work well at all. I would like to move the upper shock mount up to give the cars the suspension travel the leaf springs need.
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: lowflyingdart] #1457985
06/25/13 04:54 PM
06/25/13 04:54 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
We kinda knew this was going to be bad for weight transfer and it porpoised to the 300' than ran great .....just looking for info for a friend
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: 10secGTX] #1457986
06/25/13 05:11 PM
06/25/13 05:11 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: BBLM23] #1457987
06/25/13 07:26 PM
06/25/13 07:26 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
why not the use the street linx 4 link setup he makes as well? they are supposed to work together nicely.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: mopardude318] #1457988
06/25/13 10:28 PM
06/25/13 10:28 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
I don't use an alterkation, I have a Bondo Bob front suspension, but I had a 1.420 60' last week with my SS rear suspension. went 10.560...
Re: Anyone Racing a Leaf spring rear with the Alterkation [Re: J_BODY] #1457989
06/26/13 02:08 AM
06/26/13 02:08 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Depends on how much powrt you make how much travel you will need. The more power the less travel you will need. Low powred cars will need more travel than a higher powered car. The alterK does not give you much travel at all, 3-3.5" is about the most I have seen. Lots of cars running well into the 7's on Caltracs, but they limit front end travel.
