Exhaust hanger location. 69 a-body #1457907
06/25/13 10:13 AM
06/25/13 10:13 AM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
69 Barracuda. need a picture showing the location of the passenger side exhaust hanger above the rear axel area. maybe some measurements relating to the seat belt reinforcement plate as seen in this picture.
Re: Exhaust hanger location. 69 a-body [Re: 2abodymcodes] #1457908
06/25/13 12:02 PM
06/25/13 12:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What are you going to use for tailpipes ? If you use TTi they stock hangar locations are not used ... at least they aren't on a 69 Dart.
Re: Exhaust hanger location. 69 a-body [Re: JohnRR] #1457909
06/25/13 04:42 PM
06/25/13 04:42 PM
Shelby, Ohio
2
Shelby, Ohio
I'll be going as close to original as possible. it's for a 340 4 speed car.
Re: Exhaust hanger location. 69 a-body [Re: 2abodymcodes] #1457910
06/25/13 06:12 PM
06/25/13 06:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Then TTi may not be an option , their dart pipes are not even close , my car is an original 383 car and their tailpipes were a huge waste of money in my case.
Re: Exhaust hanger location. 69 a-body [Re: JohnRR] #1457911
06/26/13 05:08 PM
06/26/13 05:08 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I used Accurate headpipes and mufflers on my 68 383 Dart GTS with NOS tailpipes. I had to use reducers on the outlets of the mufflers so the little tiny factory tailpipes could be used. The rest of the Accurate system was nice, but if you buy where the headpipes are shipped to you then you get two pieces. If you buy in advance and have Tom bring them to you at a show then you can get them in one piece.
JB Rhinehart, Realist
A-Body's RULE!
Re: Exhaust hanger location. 69 a-body [Re: 2abodymcodes] #1457912
06/26/13 05:45 PM
06/26/13 05:45 PM
Detroit, Michigan
fjr340gts Offline
fjr340gts  Offline
Detroit, Michigan
Don't have measurements, but you can see where the bracket is in relation to the seat belt anchor.
Here is the left side:
and here is the right side:
Re: Exhaust hanger location. 69 a-body [Re: 2abodymcodes] #1457913
06/28/13 08:00 PM
06/28/13 08:00 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Can't quite tell, but your photo seems to show 3 large holes and 2 small holes. My 69 Barracuda has 3 large holes but only one small screw hole to mount the "plate assembly" inside the car. See the plate assembly at 69 Plymouth FSM, page 11-4, fig. 3, view E.
Maybe you are missing the R side exhaust hanger bracket that goes under the car and the plate assemply that goes inside the car with 3 bolts to fasten the bracket to the floor pan?
Here's a photo of my unmolested 69 Barracuda. I ordered the car in the fall of 1968.
Re: Exhaust hanger location. 69 a-body [Re: kentj340] #1457914
06/28/13 08:03 PM
06/28/13 08:03 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Closeup photo
Re: Exhaust hanger location. 69 a-body [Re: kentj340] #1457915
06/28/13 08:33 PM
06/28/13 08:33 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's a photo of the bare metal plate assembly that goes inside the car. The 3 bolts are round flat head machine screws 1/4-20 x 9/16 spot welded to the plate. The hole in the center of the plate is for a Phillips pan head tapping screw #10-12 x 1/2, zinc plated.
The plate and bolt heads are hidden behind the back seat, so hex head machine screws could be used. If you need to make a plate assembly, it is simply sheet steel 0.056" thick with 2 bends. PM me for a drawing or more details.
Re: Exhaust hanger location. 69 a-body [Re: kentj340] #1457916
06/28/13 08:53 PM
06/28/13 08:53 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This bare metal R side exhaust hanger bracket is available as a reproduction item from somebody. It mounts to the plate assembly with 3 Keps nuts, conical, same as B-11479, shown on page 52 at:
http://www.amkproducts.com/Catalog_PDF.htm
A J-nut fits in the square hole and is 5/16-18, similar to B-11516, page 58 at the link above.
Re: Exhaust hanger location. 69 a-body [Re: kentj340] #1457917
06/29/13 10:46 AM
06/29/13 10:46 AM
Shelby, Ohio
2
Shelby, Ohio
thanks kentj340. that's the info i was looking for.
