Milodon Bronze Gear/oil pump shaft
#1457763
06/24/13 10:36 PM
06/24/13 10:36 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Greetings Replacing my worn out Mopar Perf. bronze gear and bought a new Mopar part and it was machined wrong (would not go into the oil pump - the hex was not a hex. So I returned it and got a Milodon part. Nicely made, however it looks like there is only a split pin through the gear/shaft. Do you know if its keyed in some other way, or does the split pin have to take all of the load??
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Milodon Bronze Gear/oil pump shaft
[Re: oldiron]
#1457764
06/24/13 10:45 PM
06/24/13 10:45 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#1457765
06/24/13 11:05 PM
06/24/13 11:05 PM
oldiron
New Hampshire, USA
Hey Larry, went to a roller last year. The gear drives the oil pump and distributor. The MP part had a big heavy pin, while this looks like an 1/8 split pin. So if the gear/shaft is keyed, then the pin only keeps the gear from popping off the oil pump shaft, but if not keyed, then if the split pin shears.....toasted motor
[Re: oldiron]
#1457768
06/25/13 12:10 AM
06/25/13 12:10 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I've used them for years. Never had a problem with the roll pin. The gear is pressed onto the shift with a pretty mighty interference fit. Try taking one apart. Even the hydraulic press was groaning.
[Re: torkrules]
#1457769
06/25/13 12:58 AM
06/25/13 12:58 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Yep.
